Suspension & Brakes Theory, alignment, spring rates....
Using Koni Yellows with Ebay Coilovers
Old Aug 16, 2008 | 07:22 PM
shadohconspiracy's Avatar
Default Using Koni Yellows with Ebay Coilovers
okay so i was thinking about getting koni yellows to go with my ebay coilovers. well basically i am just going to use the springs without the threaded perch. I use to run it with stock shocks at a higher ride height and it was pretty comfortable and i don't mind it at all untill i decided to slam the car and run it with the perch. Now i am bouncing all over the place. I even know the spring rates . F:450lbs R:350.
Question:
Since there is 3 position i can mount the spring holder thing on the koni, which one should i run it on? Will i need to cut my bumpstops? thanks.
Unmexicano
Suspension & Brakes
Oct 29, 2010 12:15 PM
My JDM EJ8
Suspension & Brakes
Dec 1, 2008 02:46 AM
scootibum
Suspension & Brakes
Mar 25, 2007 03:03 PM
iLLA
Dec 20, 2005 01:30 PM
I6turbo
Suspension & Brakes
21
Feb 25, 2005 12:27 PM
