bar in trunk hits speaker magnets
Old Aug 16, 2008 | 06:08 PM
twiztid00002's Avatar
Default bar in trunk hits speaker magnets
does anyone else have rear speakers with a bigger magnet than stock ones and we you close the trunk, the 2 bars that i guess hold the trunk open, they hit the magnets?
5th gen
Old Aug 16, 2008 | 06:41 PM
prion's Avatar
Default Re: bar in trunk hits speaker magnets (twiztid00002)
5th gen and 4th gen are the same in this regard. i built a 4x10 sub enclosure and mounted it to my rear deck. i replaced my bars with trunk struts. check out how these people did it here:
http://www.preludeonline.com/f...1345/
its not expensive or too hard to do and will give you all the clearance you need.
or you could just make a mount for your rear speakers to lift them up a bit (such as a cut piece of MDF)
Old Aug 16, 2008 | 06:54 PM
Default Re: bar in trunk hits speaker magnets (prion)
so i just drill a hole in that trunk bar and get a bracket for the wall and attach em with the strut?
Old Aug 16, 2008 | 07:03 PM
prion's Avatar
you've got to remove the trunk bars. i used a big crescent wrench to do it, some people use crowbars. they do have a bit of tension on them so dont lose control of the bars taking them out.
you can get some brackets and bolt them to the metal seatback as in the pics, then install the struts. it takes a little finesse to make sure the holes are drilled in the right spots so measure a couple times before you give it a go.
Old Aug 16, 2008 | 07:28 PM
BlackCatt's Avatar
I have seen some universal speaker mounts which lift the rear speakers about 60mm off of the rear parcel shelf, they come in 6" and 6"X9" sizes. I saw them one day at my local auto shop, and have since seen them at another auto shop also. They shouldn't be hard to find or just make your own like prion suggested.
Old Aug 16, 2008 | 08:01 PM
MikeLuder's Avatar
i just re-used the stock speaker mount, cut it out to fit the new speakers (alpine-R) and it just barely hits the bars after its bolted down. its not that bad, i got them to fit. took some time tho. also, have the amp mounted underneath the bars on a rack, which also just barely fits.
Old Aug 17, 2008 | 04:17 AM
mattsnooz's Avatar
Default Re: bar in trunk hits speaker magnets (MikeLuder)
yeah, can't exactly fit a dead body in the trunk of a prelude....boy would I like to try though hheheheh.
Those spacers is all you need. The stock covers should still be able to be used too hopefully.
I wouldn't bother removing those tie bars in the trunk though. WAY too much work. Way more work than it would take to install those spacers to raise your speakers.
Old Aug 17, 2008 | 06:16 PM
Default Re: bar in trunk hits speaker magnets (mattsnooz)
i put those struts in today...wasnt too hard..i just used bolt cutters and cut the stock 2 bars(kinda scary lol). and just put one strut on the left side i got from pepboys for 17 dollars and wen i pull the trunk lever it lifts up about half way. it turned out pretty nice
srg
May 14, 2009 01:17 AM
lude_si_95
Audio / Security / Video
Sep 30, 2004 05:30 PM
jwogen1
Mar 10, 2004 05:32 PM
Preludster
Oct 17, 2003 05:04 AM
drives_a_honda
Apr 24, 2003 05:38 AM
