Dohc ZC IM vaccum?
Old Aug 16, 2008 | 05:55 PM
XplicitzOldSkoolDA's Avatar
Default Dohc ZC IM vaccum?
I just got my Dohc ZC engine along with a ZC transmission, I double checked the transmission and it doesn't have the bar so it's confirmed to have LSD, It also came with the ZC intermediate shalf as pictured below. I checked the timing belt and it's in mint condition, all gaskets are good, no leakage. Did a compression test, leak down test, and a oil pump pressure test, (I work for a JDM motor warehouse).
Anyways, I started to put the engine in, everything went good except for 2 holes on the Dohc ZC intake manifold. What goes to those 2 plugs?
Also, Since I'm going to be using the ZC intermediate shalf, what axle do I need? I have two DA axle that I could use if it would work.. Thanks in advances.
Thanks!
Old Aug 16, 2008 | 06:03 PM
97grnrs's Avatar
Default Re: Dohc ZC IM vaccum? (XplicitzOldSkoolDA)
there just vacuum plugs. if all your vacuums are already ran just cap them off.. unless u got a sensor or something that still needs a vac line. sometimes u wont use them all. and i thnk the 90 integra axels work.. do a search for it under the faq its in there.
Old Aug 17, 2008 | 07:22 AM
jlicrx's Avatar
you need 90-93 Integra axles - one left and one right - remove the dust rings from the hubs
malik289
Mar 16, 2009 09:43 AM
RACEPAK
May 18, 2005 11:03 PM
allmotorEG-SI
Oct 1, 2001 01:19 PM
