Coolant Reservoir
yes.. once the car heats up it will sprue out of the hole at the top of the rad where the coolant res is supposed to plug in...i belive you can over heat when its not being used
I wouldn't run it without a resivoir. the overflow is going to make a mess. You can manufacture something can't you? use an empty container that can hold coolant. Its not rocket science. The overflow which occurs with fluid heating and expansion is dumped into the resivoir through that hose that taps off where your radiator cap sits. If you have no hose just find one that fits the fitting in below the rad cap, and than run that hose to any empty sealed container and call it a day.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by E-Money »</TD></TR><TR><TD CLASS="quote">Gatorade bottle</TD></TR></TABLE>
X2
Not mine, but taken from another thread.
X2
NAPA sells a universal coolant overflow tank, with cap for literally 8 dollars, just go buy it and install it, 8 dollars is worth saving ur engine from possibly overheating.
BTW, im digging the gatorade bottle
Modified by h23prelude at 8:48 PM 8/18/2008
raju687
Sep 16, 2011 05:42 PM
turbotime
78
Aug 3, 2005 05:09 PM
