my k20a blue print racing Itr all motor build
Old Aug 16, 2008 | 04:17 PM
ITR.#1446's Avatar
Default my k20a blue print racing Itr all motor build
I have had my car off the road for about 4 to 4.5 years now. I originally just bent valves in my stock b18c5 and tore the whole motor down to make sure everything was ok and wanted to build a n/a setup. Bought parts for it and then decided i wanted to go turbo but didnt have the cash at the time so i waited and then started hearing about the k swaps. So i purchased off my friend a k20a rbc motor from a friend that is out of a euro r accord. The rbc euro r accord motor is weird because it is setup like a k24. The head is the same i think or very similar to the new civic si and comes stock with the rbc that many people put on their type s motors, the block is a k20a and the oil pump has balancing shafts like a k24. I was originally just going to run blue print stage 2 cams and valve train but when i proceeded to compress the cylinders to change the valve springs air was rushing out thru the exhaust and intake ports . So i tore the motor down and it looked in bad shape on the inside. So i sent the motor out to blue print to get built. I had the following done:
Stage 1 head work with over sized intake valves
Flat faced intake and exhaust valves
Blue print valve springs and retainers
Wiseco 11:7 comp pistons
Blue print light weight rods that i had teflon coated
Teflon coated crank
I also had to purchase an itr trans since a the euro r trans casing in like a k24 one also and would not work. I put in an excedy 9 pd flywheel and stage 1 clutch.
other parts in my build are:
rdx 410 cc injectors
bdl fuel rail
aeromotive fpr
velocity stack with k&n filter
hasport mounts
hasport stage 1 axles
hytech modified oil pump
r crew header
spoon wire cover
fake spoon valve cover
hondata k pro
arp head studs
samco yellow hoses
hybrid racing fuel lines
rsx radiator
chain tensioner modified by chunky
I am 99% done just need a catback, o2 sensor, and tune by jeff evans
. I wish i would have taking more and better pics but i am not the kind of person to take alot of pics of things. Also thru the process i did a ok job doing a wire tuck for my first time. I cant wait till its running its been soooo long since i have driven the R. Well here are some crappy pics lol.
Oh i still need to save up money for paint now.
Modified by ITR.#1446 at 10:21 PM 8/20/2008
Old Aug 16, 2008 | 05:04 PM
JDM_CRX_PLEASE's Avatar
thats niceeee.
so may i ask how long it took and how much everything was at the end?
CWTegRNo.160's Avatar
dats hawt!
Old Aug 16, 2008 | 05:11 PM
ITR.#1446's Avatar
Default Re: (JDM_CRX_PLEASE)
With the price of the motor, getting it built, trans, i would say 10k+ plus easily i never really added up the cost of everything yet. I would have not spent so much if the motor hadn't needed to be built and prob is the reason why it took so long to finish it.
thanks for the comment
Modified by ITR.#1446 at 11:48 PM 8/16/2008
Old Aug 16, 2008 | 05:15 PM
Doespike's Avatar
Default Re: (ITR.#1446)
Wow, off the road over 4 years....that must have been tough.
GL getting that final 1% done and enjoy the drive
Old Aug 16, 2008 | 06:03 PM
neo_'s Avatar
Default Re: (Doespike)
Weak.
Old Aug 16, 2008 | 06:35 PM
get RIGHT's Avatar
Default Re: (neo_)
Wow, that's a long time. Hope you get her going soon. Sounds like you used quality parts.
Old Aug 16, 2008 | 06:56 PM
totsie7944's Avatar
Default Re: my k20a blue print racing Itr all motor build (ITR.#1446)
Looks like you got a nice setup man there man..Jeff Evans FTW!
Old Aug 16, 2008 | 07:17 PM
omiehomie's Avatar
Default Re: my k20a blue print racing Itr all motor build (totsie7944)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by neo_ &raquo;</TD></TR><TR><TD CLASS="quote">Weak. </TD></TR></TABLE>
ok and i guess your setup is gods gift to the world
to the OP good job man i know funding for a nice project with specially picked parts is tough to get done in a timely fashion
Old Aug 16, 2008 | 07:38 PM
EARLdaSQUIRREL's Avatar
official honda whore
Default Re: my k20a blue print racing Itr all motor build (omiehomie)
i coulda swore you totalled out your itr, maybe it was another one
nice setup, looking to do something similar in the fall/spring to my car
Old Aug 16, 2008 | 08:20 PM
hmm over 10k+ plus you say and you picked specific parts for your build also and did a rebuild on the motor.
i was thinking it be maybe more but thats great to hear/
im saving up for a k20a swap myself so thats why i asked :] im trying to get an idea
GOOD SHIETTTTTTTT!
Old Aug 16, 2008 | 09:04 PM
mugenr#1011's Avatar
looks good. man i missed my itr after a week of not driving i couldnt imagine 4 years..but to planning and making it right
Old Aug 16, 2008 | 09:57 PM
cuonglogan's Avatar
Default Re: (mugenr#1011)
looks good so far
you coming to the thanksgiving meet?
Old Aug 16, 2008 | 10:22 PM
rhd94teg's Avatar
nice setup what kind of power u think u will be making
Old Aug 16, 2008 | 10:41 PM
ITR.#1446's Avatar
Default Re: (rhd94teg)
thanks for all the nice comments guys i was actually kind of iffy posting it up because i know their is allot of people here who disagree with k series but everyone has their own preference and likes/dislikes.
that totaled r was a friends car that i stripped and bought another r shell and brought it back life.
for the price i was just throwing that out there it could easily be more i bought allot of parts in the past couple years when things were just coming out and nothing could be found used. now with this being a new fad you can easily find parts allot cheaper and used which can save allot of money. i also wish my friend didn't hold onto the motor for a year so i could of went back to the engine co. he purchased it from and shown it was blown but stuff happens, and i think it was better anyways now i know i have a fresh motor in my car.
Old Aug 16, 2008 | 10:47 PM
ITR.#1446's Avatar
hopefully i can make it to the thanksgiving meet i will def be two toned still but i forgot to mention one set back was being scammed 850 for a k pro on clubrsx paypal did not get me any money back
Old Aug 17, 2008 | 08:30 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR.#1446 &raquo;</TD></TR><TR><TD CLASS="quote">hopefully i can make it to the thanksgiving meet i will def be two toned still but i forgot to mention one set back was being scammed 850 for a k pro on clubrsx paypal did not get me any money back </TD></TR></TABLE>
now that sucks....scammers
Old Aug 17, 2008 | 09:46 AM
Numba1 K Series's Avatar
Hi!
MOAR pics of the car!
Old Aug 17, 2008 | 12:49 PM
ITR.#1446's Avatar
Default Re: my k20a blue print racing Itr all motor build (Numba1 B Series)
haha ill take more pics if you want but its nothing special stock wheels, interior jsut omni coil overs
Old Aug 19, 2008 | 08:19 AM
RopethisS2K's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR.#1446 &raquo;</TD></TR><TR><TD CLASS="quote">haha ill take more pics if you want but its nothing special stock wheels, interior jsut omni coil overs</TD></TR></TABLE>
wow amazing man, just remember all the time you took its well worth it in the end! Cant wait to see some vids of this beast. Great work bro, best of luck with the remainder
Old Aug 19, 2008 | 09:09 AM
RTW DC2R's Avatar
brian nice to FINALLY see a motor sitting in that engine bay! good luck gettin the rest finished up.
now clean up that [freak]in garage lol
Old Aug 19, 2008 | 02:05 PM
ITR.#1446's Avatar
Default Re: (RTW DC2R)
haha right its been so long since it was on the road......garage is alittle better now lol but i still have 2 subaru swaps and mad wrx parts all over next i have to finish my brother's car and then it should be reasonably clean in there
Old Aug 19, 2008 | 04:34 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR.#1446 &raquo;</TD></TR><TR><TD CLASS="quote">thanks for all the nice comments guys i was actually kind of iffy posting it up because i know their is allot of people here who disagree with k series but everyone has their own preference and likes/dislikes.
in my opinion i think that a k series is the perfect powerplant for an integra. its worth the money to swap one in and you have way more room left over to make more power out of it.
my friend spent 1 year and almost $6000 to build his LSV and have it tuned by church auto. it made 245whp. so i mean i can spend around $6k on a fullbuild or $6k on a K series swap and have room to improve and pass up 240hp easily. but thats just me :]
Old Aug 19, 2008 | 05:40 PM
1sikitr's Avatar
Old Aug 19, 2008 | 05:59 PM
zacatkings's Avatar
Default Re: my k20a blue print racing Itr all motor build (1sikitr)
those yellow samcos are fire.....
