wired jdm fogs using, not coming on
Old Aug 16, 2008 | 03:52 PM
HONDRETTI's Avatar
Default wired jdm fogs, not coming on
i used the sticky for wiring jdm foglights exactly, everything is wired correctly. they wont come on. bulbs are good. is there a connection i need to make up front in the engine bay?? please help im in the garage at the moment trying to figure this out. thanks.
Old Aug 16, 2008 | 11:59 PM
jdmdc2boi12's Avatar
Default Re: wired jdm fogs, not coming on (HONDRETTI)
is how u did it
https://honda-tech.com/zerothread?id=2361917
Old Aug 17, 2008 | 06:43 AM
HONDRETTI's Avatar
Default Re: wired jdm fogs, not coming on (jdmdc2boi12)
https://honda-tech.com/zerothread/2195061
no i used this one. i figured out all the connections, but now i still not getting power. can anyone verify the pins i plug into under the dash to the fuse box, for a 98?
Old Aug 17, 2008 | 10:12 AM
EARLdaSQUIRREL's Avatar
official honda whore
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HONDRETTI &raquo;</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread/2195061
no i used this one. i figured out all the connections, but now i still not getting power. can anyone verify the pins i plug into under the dash to the fuse box, for a 98?</TD></TR></TABLE>
the pins should be the same for the under dash fuse box... do you have a way to check electical connections or no?
Old Aug 17, 2008 | 03:53 PM
HONDRETTI's Avatar
Default Re: wired jdm fogs, not coming on (EARLdaSQUIRREL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EARLdaSQUIRREL &raquo;</TD></TR><TR><TD CLASS="quote">
the pins should be the same for the under dash fuse box... do you have a way to check electical connections or no?</TD></TR></TABLE>
yeah i have a dvm, i have to test each plug when i feel like trying again since i gave up last night ive been enjoying the day today
the write up calls for plugs 1, 3, and 5. i was just wondering if that includes the brown plug and unplug it or starts after from the left. i havent figured out what purpose the brown plug is for.
this is how it looks, sort of...
(brown plug in use) (empty) (empty) (empty) (blank) (empty)
Old Aug 22, 2008 | 02:04 PM
dude, did u use any relay? cuz i didnt use any and mine still works fine! hit me up if u need any help..
wHiTeGhOsTdC5
Mar 8, 2008 07:34 AM
kuso1
12
Apr 26, 2007 11:39 AM
skiracer8148
May 23, 2006 10:56 AM
sinesterxone
Feb 1, 2006 06:42 AM
Mendes
Feb 22, 2004 11:53 AM
