B16A2, CEL 61...need a little input
Ladies and gentlemen we are floating in space...
My car has been choked up under ~3,000 rpm for a while now, but I haven't been able to find the problem. I finally got the CEL on the other day, and it's throwing code 61 (primary O2 sensor).
So my question is pretty simple I guess. Is it possible for a bad O2 sensor itself to cause the car to bog down heavily at low RPM? Or is it more likely that the O2 sensor is still good and detecting a bad mix due to whatever problem is causing the car to bog? I just don't wanna go on a wild goose chase.
Thanks!
Thanks!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaCamp »</TD></TR><TR><TD CLASS="quote">if its a bad 02 it wouldn't bog just that your gas would get eaten up really fast has to be something else </TD></TR></TABLE>
Yeah, strangely my mileage has been significantly better since the bogging started.
Unfortunately I don't know a single thing about what a CEL from the primary O2 sensor means.
hondaowner
May 29, 2005 12:33 PM
scratchline20
Aug 9, 2003 10:37 AM
