Skunk2 Intake Manifold Help
Old Aug 16, 2008 | 02:21 PM
tree fingers's Avatar
Default Skunk2 Intake Manifold Help
http://www.ff-squad.com/tech/howto/sk2manifold/
I have been following these instructions to help with the installation, but after reading a bit of the skunk 2 instructions [the one from their website] I'm a little confused.
The skunk2 guide says that you need to ziptie the EVAP purge control solenoid valve to the new intake. The ff-squad guide doesn't even mention the valve. Moreover, I'm not even sure if I have the valve.. let alone what it really looks like. It should connect to the charcoal canister right?
So.. the question is.. Do I need that valve?
I know where the PCV valve goes onto the new intake, but.. as for everything else.. I'm not 100% sure..
For instance, the FPR has two ends. The diagram shows where the vacuum hose for the top part goes, but not the bottom.
If anyone could post detailed pictures/diagrams of where all of these vacuum hoses go I'd really appreciate it.... because I'm [freak]ing lost.. I've tried searching, most of the archived pictures are no longer working.
Modified by tree fingers at 3:26 PM 8/16/2008
Old Aug 16, 2008 | 02:37 PM
IndySporty's Avatar
Default Re: Skunk2 Intake Manifold Help (tree fingers)
The bottom hose for the FPR is the fuel line out to the gas tank return. The valve you are referring to I have successfully removed from several of my personal vehicles OBD0 and OBD1 without any check engine light. Most everything just needs vacuum connected to it, doesn't matter where you hook it up.
Old Aug 16, 2008 | 06:57 PM
Dc4iNtEgRa's Avatar
Is Partying at your House
Default Re: Skunk2 Intake Manifold Help (IndySporty)
What engine is in the car? The EVAP purge solenoid is on the firewall if you are OBD-0. On OBD-1 it's on the intake manifold.
Also, the EVAP purge soleniod goes to the charcoal canister.
Old Aug 25, 2008 | 08:14 PM
Default Re: Skunk2 Intake Manifold Help (Dc4iNtEgRa)
It's a GSR motor. But, you were right.. it is on the firewall. Thanks!
wasapyt
Jul 20, 2010 03:37 AM
RiversideS13
11
Jul 21, 2007 08:11 AM
skunk2gsr
Apr 21, 2004 05:18 PM
99gs-r
May 25, 2003 09:00 AM
