Suspension & Brakes Theory, alignment, spring rates....
Can I use a 98 GSR Brake booster and master cylinder in a 95 hatch?
Old Aug 16, 2008 | 08:40 AM
MidwestAutoWorks's Avatar
Default Can I use a 98 GSR Brake booster and master cylinder in a 95 hatch?
Im currently parting a 98 GSR, but some of the stuff i plan on keeping and putting in my hatch shell. currently the shell has nothing in it and Id like to take as much stuff from the GSR out of it and put it in the hatch.
Has anyone worked this combo yet?
Old Aug 16, 2008 | 12:34 PM
zacatkings's Avatar
Default Re: Can I use a 98 GSR Brake booster and master cylinder in a 95 hatch? (MidwestAutoWorks)
im running the 1" master and booster out of a dc in my eg8 working good.
Old Aug 25, 2008 | 10:30 PM
BrakeExpert's Avatar
Default Re: Can I use a 98 GSR Brake booster and master cylinder in a 95 hatch? (zacatkings)
Yes you can. Usually you want to just use the master cylinder, which will bolt right in place without modification on some 92-95 civic models, others will require bending one of the hard lines that connect to it. The brake booster can be used but will space the master cylinder forward more, since the integra ones are bigger and both hardlines will need to be bent and adjusted a bit.
Old Aug 26, 2008 | 07:10 AM
IN VTEC's Avatar
Default Re: Can I use a 98 GSR Brake booster and master cylinder in a 95 hatch? (BrakeExpert)
It depends on what year Integra the master cylinder comes from. A '98 to '01 brake master cylinder is just a bolt on. No lines need to be bent or cut and reflared.
If you try to swap in one from a '94 to '97, you'll have to bend the front and rear lines, and cut and reflare the rear line to use a M8 nut.
Old Sep 3, 2008 | 12:18 PM
HiProfile's Avatar
Default Re: Can I use a 98 GSR Brake booster and master cylinder in a 95 hatch? (IN VTEC)
You still have to bend the front line from an angle to straight down. I just put on a 94-97 1" on my 95 EX, and my brother had a 98-00 that he brought over to compare. Mine required bending the rear to the other side, as well as reflairing to use the larger fitting.
The only real issue is bending/flairing/fitment. The 1st two depend on tools & skill, the last depends on whether you want to pull your manifold off or not. I have motor mount inserts, so my options were limited.
BTW its pointless to use a larger mc/bb unless you infact have larger caliper pistons. I upgraded to ITR calipers and 11.1" rotors at the same time.
Old Sep 13, 2008 | 03:59 PM
accarroll's Avatar
im getting ready to do this to mine.
Old Sep 16, 2008 | 05:49 PM
jjr's Avatar
jjr
I'm getting ready to do this to mine to.
alscrx
May 9, 2008 04:34 PM
88Civichtc
Mar 30, 2005 03:56 PM
ben_eg6
12
Dec 11, 2004 05:07 PM
