bought b18a1 dont know what year
Old Aug 16, 2008 | 07:55 AM
xaine's Avatar
Default bought b18a1 dont know what year
bought b18a1 dont know what year. it has square grey distributor plug ins. it had a four wire 02 sensor.
i know the obd0 is supposed to plug into my current harness with a computer change.
i has the swap mounts, axles, trans already
i just know this engine i bought isnt a obd0
i need to know what this engine is and what i have to do to make it work
Old Aug 16, 2008 | 08:28 AM
_Keith_'s Avatar
well if its not obd0 then its obd1 and its a 92 93 motor.
Unless I am missing somthing else that you are asking you already answered your own question.
Old Aug 16, 2008 | 09:11 AM
Crx Jimmy's Avatar
Default Re: (_Keith_)
if its a b18a1 its a 90-91 the b18b came on 92 up vehicles. it might have been converted to obd1. if you have the obd1 dizzy and 02 just get a jumper and use a obd1 ecu
Old Aug 16, 2008 | 11:40 AM
CRXRedSled's Avatar
]<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by _Keith_ &raquo;</TD></TR><TR><TD CLASS="quote">well if its not obd0 then its obd1 and its a 92 93 motor.
Unless I am missing somthing else that you are asking you already answered your own question.</TD></TR></TABLE>
I agree
If for your 90 Si:
Besides some other basics, you already have everything you need to start man!
modified shift linkage or aftermarket
get preferably a P28 ECU
you can upgrade the brakes to 90-93 while you're at it too
Old Aug 16, 2008 | 12:38 PM
Honda Tool's Avatar
2010 Honda-Tech Poker champion
Default Re: (Crx Jimmy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crx Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">if its a b18a1 its a 90-91 the b18b came on 92 up vehicles. it might have been converted to obd1. if you have the obd1 dizzy and 02 just get a jumper and use a obd1 ecu</TD></TR></TABLE>
b18a1 is 90-93 b18b is 94+...
b18a 90-91 obd0, and 92-93 obd1
Old Aug 16, 2008 | 03:02 PM
Crx Jimmy's Avatar
Default Re: (Honda Tool)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda Tool &raquo;</TD></TR><TR><TD CLASS="quote">
b18a 90-91 obd0, and 92-93 obd1</TD></TR></TABLE>
I used to have a 93 integra. it had a b18b motor in it. it was bought new from acura that way so as far as I know the 90-91 were the only b18a's and 92-93 had b18b's I might be wrong maybe my car was a freak but it was bought new that way
Old Aug 16, 2008 | 03:24 PM
guy_from_nerk's Avatar
90-93 No Jimmy your wrong. Not to be a dick but 90-93 Integras has B18a or B17a(92-93 GSR). No way did your 93 come from acura with a B18B since it hadnt even been made yet lol
Just look at the head, on the front of the block there will be markings inside circles that will tell you what year the motor is.
Yellow dizzy plugs-obd0
Grey plugs=obd1
Old Aug 16, 2008 | 04:38 PM
xaine's Avatar
thanks guys
my other main question is.
can i make this motor obd0?
or do i have to make my car obd1?
any what is involved to make it work
Old Aug 16, 2008 | 06:23 PM
Honda Tool's Avatar
Default Re: (xaine)
You could do it either way. Major difference is the distributor. I think the only other difference is some of the intake sensors. Not 100% I just put a obd0 b18a1 into a obd1 DA. I just used original intake, and distributor.
Old Aug 16, 2008 | 07:04 PM
CRXRedSled's Avatar
get a OBD0 to OBD1 conversion harness unless you're good at wiring yourself. Here is one place you can get it:
http://www.boomslang.us/obd0to1.htm
Here is the facts about your motor JDM and USDM:
http://www.jdmcars.com/tech/admin/bengine.pdf
http://en.wikipedia.org/wiki/Honda_B_engine#B18A1
Old Aug 16, 2008 | 08:42 PM
Default Re: (CRXRedSled)
No need to worry about converting from obd1 to obd0, just use a 90-91 distributor and ecu as well as the injector resistor box and your obd0. Everything plugs in, hell even the obd0 and 0bd1 alternators have the same plugs.
Old Aug 16, 2008 | 09:37 PM
xaine's Avatar
it seems like it would be easiest to get the obd0 dist and comp. the wiring is already there.
Is there any benefit to going obd1?
if there is i may go obd1 if its worth it.
i am planning on doing high compression engine.
dont know exaclty what pistons to use.
i know there has to be some stock pistons that will do the job.
Modified by xaine at 10:45 PM 8/16/2008
Old Aug 17, 2008 | 05:11 AM
Default Re: bought b18a1 dont know what year (xaine)
obd1 is desired for most tuning applications such as hondata, crome, ectune and neptune thus the reason people go with it.
Old Aug 17, 2008 | 11:49 AM
xaine's Avatar
so,, is the only benifit to obd1 is being able to hook up hondata or tuning apps like that.
Old Aug 17, 2008 | 01:10 PM
_Keith_'s Avatar
If you have all the obd1 parts its cheaper to just make the car obd1.
Old Aug 17, 2008 | 01:49 PM
xaine's Avatar
so i guess i am leaning toward ob1 set up in the crx.
do i have to buy the harness?
or can i make mine work somehow?
do i have to get the 92-93 harness and comp?
or will the 93-94 harness and comp work?
Old Aug 17, 2008 | 03:05 PM
Crx Jimmy's Avatar
Default Re: (xaine)
you always use the harness that came with the stock d motor and modify any plugs needed, if you had a si model all you need is a dizzy jumper harness( or repin it yourself) an ecu jumper(and obd1 ecu) and the vtec sub-wiring (jumper harness should have wires coming off of it for vtec very easy to hook up) you already have the 4 wire o2 so that should be it.
Old Aug 18, 2008 | 04:20 PM
xaine's Avatar
i found a good deal on a 93-94 complete harness
will this work?
as i am missing part of my original harness
and i wouldnt have to buy the obd0 yo obd1 jumper harness.
matmcg
Feb 27, 2008 08:05 PM
crxfreak1117
Feb 27, 2008 09:32 AM
hatchish
Nov 12, 2005 10:16 AM
Phrost
Oct 2, 2005 03:52 PM
90Integra
Jun 13, 2004 11:10 PM
