H22a throttle cable different from a H22a4???
Old Aug 16, 2008 | 06:40 AM
eg22pr's Avatar
Default H22a throttle cable different from a H22a4???
sorry for the dumb question just asking b/c the nut on the throttle cable is stripped and need to change the cable. just want to know if there all the same and i could just buy one on ebay or i need one specifically for a h22a.thanks in advance.
Old Aug 16, 2008 | 07:04 AM
eg22pr's Avatar
can any one help out?
Old Aug 17, 2008 | 04:14 AM
mattsnooz's Avatar
Default Re: H22a throttle cable different from a H22a4??? (eg22pr)
where is it stripped?
All throtle cables should be the same shouldn't they?
BUMP for clarification
Old Aug 17, 2008 | 06:08 AM
Rosko's Avatar
Default Re: H22a throttle cable different from a H22a4??? (mattsnooz)
get the throttle cable for the chassis you have and you should be good.
Old Aug 17, 2008 | 07:56 AM
lude98SH's Avatar
Default Re: H22a throttle cable different from a H22a4??? (Rosko)
you just have to adjust it to the correct tension.
Im using an h22a4 throttle cable on my euro r manifold with aebs TB
Old Aug 17, 2008 | 09:21 AM
eg22pr's Avatar
well the chassi i got is a eg coupe with a h22a in it
Old Aug 17, 2008 | 09:22 AM
eg22pr's Avatar
its stripped where the nut is the adjusting nut
Modified by eg22pr at 11:12 AM 8/17/2008
Old Aug 17, 2008 | 09:42 AM
eg22pr's Avatar
[IMG][/IMG]
Modified by eg22pr at 11:08 AM 8/17/2008
Old Aug 17, 2008 | 10:11 AM
eg22pr's Avatar
im getting an obx throttle body b/c current tb butter fly is sticking sh*t$ getting anoying
so i just want to get a new non strpped cable when i get the tb in thats all..thanks for the replies keep um comming
Old Aug 17, 2008 | 10:39 AM
98vtec's Avatar
moderator emeritus
so you want to get a POS throttle to fix your already messed up throttle?
thats a double negative
Old Aug 17, 2008 | 10:48 AM
eg22pr's Avatar
Default Re: H22a throttle cable different from a H22a4??? (98vtec)
oh man mr. negative over here...u could at least just suggest a better one a$$ wi9e?!?!?!!!cheers
Old Aug 17, 2008 | 10:55 AM
98vtec's Avatar
moderator emeritus
stock, s2000, ITR
or
http://www.maxbore.com
why would you want to put something on your car whose company is known to make cheap parts with quality out of mind?
Old Aug 17, 2008 | 11:05 AM
eg22pr's Avatar
$hit didnt know they were that bad should of came here 1st besides i wasnt trying to get a bigger tb just want the car to run good.thanks man
Old Aug 17, 2008 | 11:11 AM
jdmcivicferio's Avatar
I used a 97-01 H22 throttle cable on my eg, its nice and short and doesn't look gay in the engine bay
Old Aug 17, 2008 | 11:17 AM
eg22pr's Avatar
guess ill look for a itr tb then for the meen time ill use the obx for now
Old Aug 17, 2008 | 11:18 AM
eg22pr's Avatar
Default Re: H22a throttle cable different from a H22a4??? (jdmcivicferio)
thanks
vinuneuro
Feb 26, 2006 10:14 PM
92HB_HB
May 13, 2002 05:08 PM
