4dr performance exhaust help
i have a 91 4dr with a custom DOHC ZC stroker and my exhaust just isnt cutting it for obvious reasons. I'm trying to find a decent set up without spending too much cash, but most everything i find is for hatchbacks and crxs. the only thing i have found is a setup by OBX for like 400 bucks and i just dont want to spend that much. by this point, if your reading this, your probably wondering why i just dont make my own and the answer is simple. I cant weld for ****, and i dont want a shitty overpriced meineke POS that i'm gonna have to replace in a year anyways. any help or suggestions would be great. thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GLI »</TD></TR><TR><TD CLASS="quote">Have someone make one for you. Like a shop?</TD></TR></TABLE> Yupper, if you ask around locally or buy piping from someone like Kteller you can have any place weld it up.
I got a 4dr exhaust from the junk yard because the one on my old hatch was rusted out and the 4dr on at the junk yard was new, the axle back was a bolt on(just had to cut about a foot of pipe off of the tip to make shorter) and the other pipe needed a little trimming but not too bad, so going the other way should be easy as well, if you get a hatch exhaust just need a little fab to get it on, if you cant weld just cut the pipe in a straight area and use a pipe to slip over and some clamps
black beauty! 94 prelude
Sep 29, 2005 03:55 PM
LoveOfMoney
Jul 13, 2005 05:49 AM
Kyle244R948
Jul 18, 2004 02:05 PM
