My Jdm Zc pass smog??
Old Aug 15, 2008 | 05:13 PM
SoHc Ej1's Avatar
Default My Jdm Zc pass smog??
NEW UPDATE!!! I went to get my car smoged and the guy said my car won't pass smog because it's a jdm motor and it's not a D16 or D15. He said the 95 civics came d15 v-tec or d16 non-vtec. He said he could pass it if i pay $170
Ok I Have A JDM ZC single-cam, everything is stock. I just need some reassurance that my car will pass smog no problem or am i wrong?
Modified by SoHc Ej1 at 3:15 PM 8/25/2008
Old Aug 15, 2008 | 05:37 PM
yoontim23's Avatar
Default Re: My Jdm Zc pass smog?? (SoHc Ej1)
I don't see why it wouldent pass. Unless you have like a check engine and your car smells really bad.
Old Aug 15, 2008 | 05:48 PM
94EG8's Avatar
Seagull Management
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SoHc Ej1 &raquo;</TD></TR><TR><TD CLASS="quote">Ok I Have A JDM ZC single-cam, everything is stock. I just need some reassurance that my car will pass smog no problem or am i wrong? </TD></TR></TABLE>
Someone correct me if i'm wrong, which i may very well be, but in california doesn't the engine have be available in a USDM vehicle, IE B16A is a legal transplant because the US got B16As but the US never got a ZC and as a result even though in terms of actuall emissions it would probably pass with flying colors its not a legal swap due to the fact there was a never a ZC in the US.
Old Aug 15, 2008 | 08:15 PM
SoHc Ej1's Avatar
Default Re: My Jdm Zc pass smog?? (94EG8)
No check engine light when i have the stock headers on the car. I don't think the 92-95 civics came with b16a except maybe the Si model? I don't know
Old Aug 15, 2008 | 08:22 PM
92shade's Avatar
no b16 never came on egs (usdm that is)
Old Aug 15, 2008 | 08:38 PM
SoHc Ej1's Avatar
Default Re: My Jdm Zc pass smog?? (92shade)
ooh that's wack, all integra come dual cam atleast
Old Aug 15, 2008 | 10:59 PM
baller status's Avatar
I had a OBD0 SOHC ZC non VTEC in a 90 Si and a OBD1 SOHC ZC VTEC in a 93 DX and I was able to smog them both in California.
These engines are designated as equivalent engine replacements so they're legal in CA, although in the case of my 93 DX, technically a smog ref certificate was required but in three smog checks no smog tech ever noticed it was not a stock engine. Since it's a SOHC basically it just gets ignored.
Now I live in a state where I can have whatever engine I want as long as the basic smog equipment is there and it passes the sniffer. And that's how it should be.
"Japanese Replacement Engines
Used engines imported from Japan can be used as replacement engines as long as the engine being used has been identified as functionally identical to the original engine. Please refer to the engine importers catalogue to determine if a replacement engine is legal for installation in your vehicle. "
http://www.arb.ca.gov/msprog/aftermkt/replace.htm
Old Aug 15, 2008 | 11:05 PM
labtec2's Avatar
Default Re: My Jdm Zc pass smog?? (baller status)
maybe you can find a shop that will "smog" your car
but i think it should pass. sounds like your in the clear
Old Aug 15, 2008 | 11:16 PM
EH3 JR's Avatar
You may pass the sniff test. But, to pass it legally, the engine should be available in U.S. market and its the same year of your stock engine or newer.
For example, B16A is available for EK Si. Then, you can get it barred on your EG to be legally smogged.
You will need to be barred if you swap in a different engine than stock. Plus, JDM engine usually fail for visual because it doesn't have EGR.
GL!!
Old Aug 17, 2008 | 11:05 AM
SoHc Ej1's Avatar
Default Re: My Jdm Zc pass smog?? (EH3 JR)
Yea, i don't plan on putting in a dual cam motor. I'm keeping it Single-cam
Old Aug 17, 2008 | 11:34 AM
IP RACING's Avatar
I had a zc non vtec In my ef sedan passed with flying colors. It looks stock most places dont check the stamping on the engine and if it looks like OE then it wont bring up any doubt
Old Aug 17, 2008 | 12:02 PM
SoHc Ej1's Avatar
Default Re: My Jdm Zc pass smog?? (IP RACING)
what's the difference between smog test and smog check or smog certificate?
Old Aug 25, 2008 | 02:15 PM
SoHc Ej1's Avatar
check first post...any help?
Old Aug 25, 2008 | 02:28 PM
94EG8's Avatar
Seagull Management
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SoHc Ej1 &raquo;</TD></TR><TR><TD CLASS="quote">check first post...any help?</TD></TR></TABLE>
Yeah, get another engine, if you wanna stay SOHC try to get a D16Z6, or see if D15B Vtecs are smog legal, i think they might be now, not sure. Sucks for you guys in california, but those are the rules you have to play by. You could pay him the $170 and have him pass it, but i don't know what would happen if you got pulled over.
Old Aug 25, 2008 | 04:40 PM
SoHc Ej1's Avatar
nothing happens when i get pulled over, i've been pulled over many times and no one has said anything about my motor and they have checked.
Old May 6, 2009 | 09:11 AM
AdicUar's Avatar
i know this is an old post but i am having a similar problem with my DOHC zc swap. the bottom end is fresh to OE spec. and the head is as well but with cams and a mild p&p. when i took it to get inspected it wont pass smog. i live in Pa. the guy said to put a new cat on it but i dont think that is the problem. i could be wrong but it seems to me that i am dumping fuel and have a real stinky tail pipe, haha no pun intended. any insight would be greatly appreciated. i dont want to spend money on a new cat if that might not be the problem.
Old May 6, 2009 | 10:50 AM
dave181's Avatar
i got a d15b y tec in my 95 civic dx and it pasd smog with flying color when i bought the car less then a year ago if you went with one youd b fine and im in california also
Old Sep 11, 2022 | 05:31 AM
K3voh123's Avatar
did u use your stock non vtec 95 civic ecu or different? Need to do a swap in my 95 dx too and been thinking going d15b vtec. I’m in cali too
Old Sep 13, 2022 | 07:38 AM
spAdam's Avatar
Loved
Community Favorite
You cannot pass smog with any JDM engine under the current rules in California.
skaternak
Sep 22, 2009 11:03 PM
6footmidget
Southern California
Aug 26, 2008 09:15 PM
EF_ST@TUS
14
Sep 8, 2007 04:02 PM
drastikmeasurez
20
Feb 3, 2004 08:17 PM
The Alchemist...
14
Aug 10, 2002 03:20 PM
