88 CRX DX engine and trans into 89 CRX HF shell - drop in fit?
the 88 21 splines are where the input shaft of the transmission fits into the clutch disc - has nothing to do with axles - you can use your HF axles with any 88-91 CRX/Civic L3 transmission (except for JDM ZC) - in fact, you would have to use the HF axles unless you swapped out the knuckles/hubs - the DX engine is DPFI and the HF is MPFI - you would need to use the MPFI intake manifold, injectors and distributor on the DX engine
Modified by jlicrx at 5:45 PM 8/15/2008
When I run the vin on my 89 and the vin on the 88 that he motor is out of they both show the same Engine: 1.5L I4 MPI
here are the two vins:
1989 - JHMED8367KS019630
1988 - JHMED8359JS003564
the 88 also had this info under the hood:
engine family: jhn1-5v5fcf-4
88 honda 1500
91 c.i.d.
I dont have any axles at the moment
Modified by CustomVW at 4:32 AM 8/16/2008
88 honda 1500
91 c.i.d.
sg2664
Oct 13, 2010 01:29 PM
1988 hf crx trans si, dx, hf splines the same for the axles into the hub and trans, i know the 89+ c
80 dolla crx hf
Jun 9, 2008 03:03 AM
50shotRex
Feb 16, 2003 05:07 PM
