Vacuum Line ?- and yes i searched
Old Aug 15, 2008 | 01:20 PM
MJOLNIRvTEC's Avatar
Default Vacuum Line ?- and yes i searched
Hey guys I just bought a car, and the engine bay was.......a mess to say the least. I spent literally all day redoing all the vac lines..seriously 4 hrs of vacuum lines..i think i wanna die..just a little. Anywho everything is now done except for a small detail..#8 The previous owner totally took it out. Will this harm operation once/if i get it running? If not should i just plug it? Thanks in advance guys
Old Aug 15, 2008 | 01:33 PM
Default Re: Vacuum Line ?- and yes i searched (MJOLNIRvTEC)
ps #8 is the intake control solenoid valve
Old Aug 15, 2008 | 03:36 PM
gstrudler's Avatar
Do you have an aftermarket intake? From what I remember, I think #8 is to open the resonator down in the fender; it works kind of like the butterflies in the IM: it only allows so much volume of air at low rpm's to help the velocity, then opens up at higher rpm's to allow more flow. If you have a short ram or CAI, it's not needed. Somebody please correct me if I'm wrong.
Old Aug 15, 2008 | 04:13 PM
dagle's Avatar
Default Re: Vacuum Line ?- and yes i searched (gstrudler)
vac lines with 8 8 8 8 8 8 all over it? yeah it should be for the OEM intake IIRC.
Old Aug 15, 2008 | 04:43 PM
Default Re: Vacuum Line ?- and yes i searched (dagle)
solid guys thanks alot. there is an aftermarket intake on it so maybe thats why its out. next question would be do i just block it or leave it open. it attaches to the manifold so im guessing something needs to be done
Old Aug 15, 2008 | 06:30 PM
mafia's Avatar
I have mine blocked off.
Old Aug 15, 2008 | 06:35 PM
Default Re: Vacuum Line ?- and yes i searched (mafia)
thanks man. secksy lude btw
Accordin2me
Aug 5, 2010 03:02 PM
MilanoLude
Sep 24, 2007 03:19 PM
sony224422
Jul 21, 2006 02:43 PM
roadawg
Oct 25, 2003 05:39 PM
