Fuel Issue?
Old Aug 15, 2008 | 01:20 PM
Ocnaj's Avatar
Default Fuel Issue?
I have a 90' CRX Si mini-me with a Y8 head on it. Sometimes when I try to start it, it runs for a few seconds then shuts off. After this happens it takes a few minutes for it to start back up again. I never had a problem with it stalling as I was driving it. It only happens when I start it up. Would the stock fpr have something to do with this?
Old Aug 15, 2008 | 10:36 PM
Ocnaj's Avatar
Default Re: Fuel Issue? (Ocnaj)
bump...
Old Aug 15, 2008 | 10:41 PM
dohczccrx's Avatar
its your main relay. when you go to start your car it is not clicking on so you pump can prime. so then your car is running on the pressure in the fuel lines from when you last shut it off. watch neext time stop and listen for the humming sound of the pump and the click of the relay turning on then off
Old Aug 19, 2008 | 04:09 PM
Ocnaj's Avatar
Default Re: Fuel Issue? (dohczccrx)
Couple questions; Is this relay for the fuel pump? If it wasn't working then how would it run at all? Where is the relay located?
Old Aug 23, 2008 | 01:06 PM
Ocnaj's Avatar
bump
JacksonD
18
Jan 8, 2011 12:34 AM
stuntinhb
Mar 4, 2007 02:59 PM
uszcrx
24
Sep 9, 2006 01:05 PM
Hugsnkisses01369
Aug 18, 2006 02:46 PM
areyouahobo
Jul 3, 2003 05:39 AM
