How big is the a/r housing on the f-max turbo kits on their turbine and compressor side?
My car tapped out at 264 whp with the f-max turbo kit at 14lbs. AEBS said that the turbo is too small and is bottoming out at around 5,000 RPM. I need a bigger turbine and possibly bigger compressor as well. Is anybody running a t3/t4e on their Preludes?
You will need to modify the F-Max manifold to run an E compressor housing on the Prelude. Someone posted a 'how to' article on PreludeOnline.com I'm sure you'll be able to find it in the Forced Induction section with a simple search.
