FS: B18b longblock and other miscellaneous B-series/EG parts
UKDM LS B18b longblock $250: Bought off of a member here awhile back, was gonna go ls-vtec but ended up selling my car. Was told it had 50k miles. Includes IM w/ hondata manifold gasket, engine harness, and alternator. Is missing a Distributor and injectors
JDM EG sunroof $15 (glass is cracked, but the motor is in good shape)
Black EG hatch cover $35 (has a small rip/crack pictured, hardly noticable when installed)
B-series Heavy duty pressure plate $25 only used roughly 100 miles
S2k/b-series Throttle Body $40 (diameter is same as itr: 66mm on the outerside/62mm on the butterfly side) Only difference between the two is the s2k tb doesn't come w/ an idle adjust screw. Will fit on b-series intake manifolds.
B-series Used (ITR) oil pump $30 (used for about 10k miles)
Downpipe w/ vband flange that was used on the Apex'i D1GP drift RX7 $10 (can be cut and modified to fit other applications)
D-series Shift Linkage $20
Located in Fontana, CA
s.patel
May 17, 2008 09:19 AM
