Engine balancing
Old Aug 15, 2008 | 11:29 AM
Red_ED8's Avatar
Default Engine balancing
OK well first things first. I have a sohc zc that I am getting ready to swap a Y8 head and maybe some pm3 pistons. The thing I wanted to get some input on is:
Will I be alright to run this set up without getting the crank and everything rebalanced after I swap the pistons??
I know it's best to get it done but I'm on a SMALL budget and the engine is going in a daily driver that will never see 8K rpm (staying with stock rev limit).
Old Aug 15, 2008 | 12:06 PM
Sean Juan's Avatar
Default Re: Engine balancing (Red_ED8)
What makes you think you will need to get it balanced just by installing some pistons and a different head? If you're leaving it at stock redline, why would you balance the crank? Honestly, I would do some more research on engine internals and how they work before working on them. Not trying to be a dick, but it will help answer most of your questions.
Old Aug 15, 2008 | 12:12 PM
Red_ED8's Avatar
Default Re: Engine balancing (Sean Juan)
I am by no means a master tech but I have rebuilt 1 or 2 D16 and I'm completely capable of swapping piston. Only reason I asked is because the guy that machined my Y8 head said I should get it all rebalanced but I think he was just trying to get more money out of me .
Old Aug 15, 2008 | 01:53 PM
Creator's Avatar
Unless you had some kind of internal engine falure it's not necessary.
preetyboi06
21
Apr 11, 2009 07:19 PM
damn_import_culture
May 4, 2005 01:00 PM
daniel89civ
17
Mar 31, 2003 04:36 AM
silo
May 9, 2002 07:17 AM
