My axle "popped" out making a turn, and the car dropped 2"....
Old Aug 15, 2008 | 07:24 AM
aleks77's Avatar
Default My axle "popped" out making a turn, and the car dropped 2"....
hey guys coming home last night i make a 90 degree right hand turn and before i can finish it the axle pops out of the hub...red grease everywhere, the boot is ripped open. The other thing i noticed is the car dropped 2 inches....could it be that the car was actually resting on the axle this whole time rather than the spring...? i dont get it, the axle has 500 miles on it.
Im getting it towed today will take pix of the damage
Old Aug 15, 2008 | 01:55 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: My axle "popped" out making a turn, and the car dropped 2".... (aleks77)
Did you install cotter pins in your ball joints after the last axle change??
Sounds like your ball joint or nut failed, causing the suspension to drop and axle to come out....get under there and see what happened?
Old Aug 15, 2008 | 02:40 PM
srmofo's Avatar
Default Re: My axle "popped" out making a turn, and the car dropped 2".... (Evs-One)
^^^x2^^^ either that or the ball joint broke
Old Aug 15, 2008 | 02:56 PM
Evs-One's Avatar
Solbros Owns Me
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Evs-One &raquo;</TD></TR><TR><TD CLASS="quote">ball joint or nut failed, </TD></TR></TABLE>
failed=broken
Old Aug 16, 2008 | 10:57 AM
srmofo's Avatar
errr ...I didnt notice that you said ball joint
Old Aug 16, 2008 | 12:35 PM
zacatkings's Avatar
Default Re: My axle "popped" out making a turn, and the car dropped 2".... (srmofo)
ouch
Old Aug 17, 2008 | 11:09 AM
perpetualburn's Avatar
That happened to me too. The previous owner before didn't replace the cotter pins on the ball joint and I never thought to look. From what it sounds, thats the exact same thing that happened to you too.
Old Aug 18, 2008 | 10:06 PM
aleks77's Avatar
you guys are 100% right, the ball joint popped out. After the last axle change i tried to tighten the damn nut but it just kept slipping like it was stripped, i put a cotter pin in, but its no where to be found now. I ordered both brand new ball joints and anything related to it, gonna replace both, and replace driver side axle under warranty
lucky this didnt happen at high speed, 10mph, altho i JUST came off the freeway
Old Aug 19, 2008 | 07:44 AM
srmofo's Avatar
Default Re: (aleks77)
next time put a pry bar in there and push the ball joint shaft into the hole while you are tightening the nut, the extra pressure helps keep the shaft from just spinning
Old Aug 19, 2008 | 07:49 AM
Evs-One's Avatar
Solbros Owns Me
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aleks77 &raquo;</TD></TR><TR><TD CLASS="quote">you guys are 100% right, the ball joint popped out. After the last axle change i tried to tighten the damn nut but it just kept slipping like it was stripped, i put a cotter pin in, but its no where to be found now. I ordered both brand new ball joints and anything related to it, gonna replace both, and replace driver side axle under warranty
lucky this didnt happen at high speed, 10mph, altho i JUST came off the freeway</TD></TR></TABLE>
Youre right, at least it wasn't at speed. If you ever need ANYTHING Honda related, my good friend Nazar lives in Blaine- he's a tech at Northwest Honda and he has a shop at his house. He's a really good guy, just PM me for his number.
For this same reason is why I do not go on "cruises" with other home built cars- it's just scary
Old Aug 20, 2008 | 08:19 AM
aleks77's Avatar
The nut is missing so ya boots on both sides of the axle are ripped and grease everywhere. Looks like the intermediate shaft and the hub/wheel bearing are ok. What else should i check for damage from somethin like this?
Old Aug 20, 2008 | 08:29 AM
Evs-One's Avatar
Solbros Owns Me
Not much else could really get damaged at such slow speeds.
Just check everything else over, get new axles and ball joints, and re-install everything correctly!
Old Dec 8, 2010 | 07:10 AM
SouthSider13's Avatar
Same thing happenned to me =(
Do i have a lower and upper ball joints?
00 civic coupe
cmasino
Honda Civic (2001 - 2005)
Jul 14, 2017 10:44 AM
01ethansh
Dec 17, 2008 12:15 PM
DarkBB4
Apr 22, 2007 09:29 PM
S.Celia
Jan 26, 2004 07:24 AM
Black_Accord
Jul 14, 2003 08:08 AM
