Clutch/ Transmission Problems!!!
Old Aug 14, 2008 | 10:58 PM
bob_long737's Avatar
Default Clutch/ Transmission Problems!!!
Ok so I need some help guys...I have a 91 Integra GS
I was driving down the road fine until i go to push in the clutch and it feels very wierd and then I try to put it in a lower gear and it wont go into any gear.
So I turn off the car and I can shift it into a different gear while the car is off. and drive fine and shift (without the clutch) but as soon I try to shift normally when the car is on it wont go into any gear.
I tried adjusting the clutch cable but had no luck. please help me!!!
Old Aug 15, 2008 | 12:22 AM
gtec8285's Avatar
Default Re: Clutch/ Transmission Problems!!! (bob_long737)
i had this problem before
this would be your clutch going out so i highly recommend that you change your clutch soon before you mess up your tranny
Old Aug 15, 2008 | 04:31 AM
na+b18c_hatch's Avatar
yeah put a clutch in it brotha. ebaymotors has pretty cheap act clutch kits, and maybe get a lighter flywheel while you're at it
Old Aug 15, 2008 | 06:30 AM
AWD Terror's Avatar
Default Re: (na+b18c_hatch)
This is very common thing to happen when your clutch goes out.
This is a very good time to look into modifying your car
Old Aug 15, 2008 | 07:49 AM
Default Re: Clutch/ Transmission Problems!!! (gtec8285)
yeah it would make sense if it was going out slowly but all the sudden? is there any way I can get a few more miles out of it actually using my clutch?
Old Aug 15, 2008 | 08:34 AM
yc_dc4mar's Avatar
i have this same problem except i just changed my clutch, flywheel, pressure plate, clutch fork and slave cyl. bled the clutch. it wont go in gear at all. the clutch doesnt dis-engage to go in gear. idk whats wrong.
Old Aug 15, 2008 | 10:17 AM
Default Re: Clutch/ Transmission Problems!!! (yc_dc4mar)
thats what im afraid would happen to me if I put in a clutch and that not be the problem... cmon guys how could it go out all the sudden?
Old Aug 15, 2008 | 10:21 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bob_long737 &raquo;</TD></TR><TR><TD CLASS="quote">thats what im afraid would happen to me if I put in a clutch and that not be the problem... cmon guys how could it go out all the sudden?</TD></TR></TABLE>
it happened to me. it can happen if one of the clutch disc springs break (which is what happened in my case). the clutch showed no obvious signs of wear, it just went up "all of a sudden"
Old Aug 15, 2008 | 01:49 PM
gtec8285's Avatar
it was probably happening already but never noticed it slipping
like i said before it happen to me without knowing my clutch was going out when i was driving home then all of the sudden my car wont go in gear
Old Aug 15, 2008 | 03:49 PM
SleeperGSR's Avatar
i have a hydro tranny but when the clutch "went" it was all of a sudden. Your clutch is shot.
Old Aug 16, 2008 | 09:00 PM
Default Re: Clutch/ Transmission Problems!!! (SleeperGSR)
The thing that I dont understand is why I can shift with the clutch when the engine isnt turning... why is that?
Old Aug 16, 2008 | 10:20 PM
jakop92's Avatar
I had the same problem up until today. Same exact symptoms EXACTLY. It all started when the reservoir on my CMC was low. It started sucking in air into the system. First thing to do is clean the engine bay real good. Make sure there is sufficient fluid. Then check for fluid leaks on the clutch master cylinder and clutch slave cylinder or in the line in between. If there is a leak it has to be fixed. There can be no air/contaminants in the system. Then bleed out the system.
Here is how you do it: You need two people. One inside one in the engine. Pump the clutch about 30 times. Then hold the clutch pedal in as far as possible. Open up the bleeder screw on the slave cylinder (right on tranny) and let the air out for asec. When fluid starts coming out, close it back up. Repeat procedure until the pedal feels normal.
Hope this helps. Its worth the try before you go and blow out so much cash on a new clutch..
Old Aug 17, 2008 | 06:03 PM
Default Re: (jakop92)
I have a cable tranny... sounds like you have a hydro....
Old Aug 17, 2008 | 06:59 PM
SleeperGSR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bob_long737 &raquo;</TD></TR><TR><TD CLASS="quote">The thing that I dont understand is why I can shift with the clutch when the engine isnt turning... why is that?</TD></TR></TABLE>
Because the engine isn't turning....that's why you can shift. When it is turning the clutch isn't disengaging the tranny, so you can't shift.
Old Aug 17, 2008 | 08:55 PM
But I push in the clutch when it comes to a stop and it does not die... does that mean its partialy disengaging or is that something else?
Modified by bob_long737 at 10:10 PM 8/17/2008
Old Aug 18, 2008 | 01:26 PM
SleeperGSR's Avatar
it means it's broke....get a new clutch
Old Aug 19, 2008 | 01:40 PM
OK!! ordered a XTD stage 2 clutch with a 8 pound flywheel off ebay.. hope it last at least a year till I get out of school and am not a poor college student any more. Should I drain the transmission fluid before taking it out? If so what kind of oil do I put in the tranny.
Any advice for me before I put the new clutch and flywheel in?? thanks
Old Aug 19, 2008 | 02:27 PM
yc_dc4mar's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bob_long737 &raquo;</TD></TR><TR><TD CLASS="quote">OK!! ordered a XTD stage 2 clutch with a 8 pound flywheel off ebay.. hope it last at least a year till I get out of school and am not a poor college student any more. Should I drain the transmission fluid before taking it out? If so what kind of oil do I put in the tranny.
Any advice for me before I put the new clutch and flywheel in?? thanks</TD></TR></TABLE>
honda MTF
Old Aug 19, 2008 | 07:41 PM
Ok honda manual transmission fluid?... anything other advice?
_Endless_
Sep 4, 2004 02:46 AM
petrv
Aug 17, 2004 02:10 AM
93civcx
Jun 18, 2004 06:25 AM
MiraiZ
Aug 12, 2003 06:18 PM
