got a CF hood and wobbles
70 or 8o MPH hood starts wobbling. i was recommended hood pins. where would they go and how do they install. 1995 acura integra . seibon CF OEM style hood.
i dont think a picture is necessary.
so were do i drill
so were do i drill
You don't have to drill holes into the radiator support, there is already holes in it that line up evenly and fit the pins. You just need to put those on, and then drill through the hood, preferably with a dremel. Take your time and do a little at a time because you can always make it bigger.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntegraCF21 »</TD></TR><TR><TD CLASS="quote">You don't have to drill holes into the radiator support, there is already holes in it that line up evenly and fit the pins. You just need to put those on, and then drill through the hood, preferably with a dremel. Take your time and do a little at a time because you can always make it bigger.</TD></TR></TABLE>
sounds great ill take a pic of my rad support and you let me know wich ones.
a dremel? can i find this in home depot or like where?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AWD Terror »</TD></TR><TR><TD CLASS="quote">LOL. When I hit 100 MPH my hood opens and hits my windshield.
How about you drive the speed limit, then you won't have to worry about it.</TD></TR></TABLE>
nobody drives 65mph so i drive with the flow of the traffic wich is 70 or 80mph i never said one hundred.
If you adjust the hood latch in the radiator support down a little bit and use the rubber sealing piece from the stock hood, you should be able to avoid the issue altogether. The wobble is caused by airflow under the hood and if you can stop that airflow you will stop the problem.
.....but hood pins are never a bad idea.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tweek_boii »</TD></TR><TR><TD CLASS="quote">
a dremel? can i find this in home depot or like where?</TD></TR></TABLE>
Yes, you should be able to find it at any home improvement store like that. It's a good tool to have for tons of things. Also start with a smaller drill bit to start the hole, then use a larger one. That will reduce the risk of cracking anything.
Get a hood pin just for the extra saftey. Recently my cousins EJ cf hood opened on the freeway going like 80mph and it dented his roof lol. Whats funny is that the hood didnt even crack and it messed up his roof pretty bad. Scarey ****.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall »</TD></TR><TR><TD CLASS="quote">If you adjust the hood latch in the radiator support down a little bit and use the rubber sealing piece from the stock hood, you should be able to avoid the issue altogether. The wobble is caused by airflow under the hood and if you can stop that airflow you will stop the problem.
.....but hood pins are never a bad idea.</TD></TR></TABLE>
ill do that but like
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jintegragsr97 »</TD></TR><TR><TD CLASS="quote">Get a hood pin just for the extra saftey. Recently my cousins EJ cf hood opened on the freeway going like 80mph and it dented his roof lol. Whats funny is that the hood didnt even crack and it messed up his roof pretty bad. Scarey ****.</TD></TR></TABLE>
scares the **** out of me so i will also do the hood pins , whats would best brand recommended? well not the best but most reliable
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rickdrizzle »</TD></TR><TR><TD CLASS="quote">haha wow, my hood doesn't wooble.</TD></TR></TABLE>
you didnt do anything special for that not to happen??
i mean if you look atmy hood i dont see how alot of air can go
in , enough to make it wobble.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Local »</TD></TR><TR><TD CLASS="quote">lol pepsi rep.
Nothing special. Just bolted right up and it's stiff like a ****.
</TD></TR></TABLE>Nothing special. Just bolted right up and it's stiff like a ****.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JuggsxCOmanDO »</TD></TR><TR><TD CLASS="quote">those rubber peices make a big difference, had them on my cf hood, and my cf hood stopped wobbling at high speeds. hood pins are ugly. </TD></TR></TABLE>
lolok at that pic above. angle eyes. kinda looks like your pos
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soontobeboost »</TD></TR><TR><TD CLASS="quote">
too bad i dont have that pos front end anymore..the original color of my bumper was white too lol.
</TD></TR></TABLE>too bad i dont have that pos front end anymore..the original color of my bumper was white too lol.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by diLLy »</TD></TR><TR><TD CLASS="quote">
Great lookin teg with the only hood pins id ever wish to see on a honda. Your remembered right, the aerocatch.
http://www.deftracing.com/aero...x.htm
Ive looked into them for their locked hood pins as theif security, they cant get under your hood they cant disarm your ****. In cali hood pins are illegal, but these arent and they look WAY better. Id color match them on whatever hood I put them on.
If you live in cali ask a cop why their illegal, your lol at his reply.
</TD></TR></TABLE>Great lookin teg with the only hood pins id ever wish to see on a honda. Your remembered right, the aerocatch.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EpicKills »</TD></TR><TR><TD CLASS="quote">Yeah they sell both, Im not a cf fan so Id only throw em on to keep my hood latched whiel Im saftely sleeping in my bed
same here.
i used to be a big CF fan.
but no more.
OEM look FTW.
</TD></TR></TABLE>same here.
but no more.
OEM look FTW.
</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JuggsxCOmanDO »</TD></TR><TR><TD CLASS="quote">
too bad i dont have that pos front end anymore..the original color of my bumper was white too lol. </TD></TR></TABLE>
what is POS ? im getting oem headlights by the way ..
i checked my OEM hood it didnt have any rubber on the latch ..
If you live in cali ask a cop why their illegal, your lol at his reply.</TD></TR></TABLE>
they are illegal ?? well either way i am going to try to get black ones the ones in the pic look like they faded ..
i cant go 70 feeling comfy , so i drive in the slower lanes
</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JuggsxCOmanDO »</TD></TR><TR><TD CLASS="quote">too bad i dont have that pos front end anymore..the original color of my bumper was white too lol. </TD></TR></TABLE>
