oil pump
I have a 95 b18c1 obd1 I'm rebuilding my motor and need to buy a new oil pump. What is the difference between obd1 and obd2 oil pumps? Because the part numbers are different and the obd2 pump is cheaper also!
found your answer in an ebay listing
Note: this pump will fit ALL b-series motors, however, the lower timing belt cover on the 90-95 integra's does not fit properly. most choose to just not use the lower cover after installing the pump, or modify it to fit, but we also have another option. in our e-bay store is a listing for a 96-01 lower timing belt cover that properly fits this pump, and you can purchase it if you choose for your 90-95 integra(if that is what you own) to replace the original lower cover. if you do not have a 90-95 integra, please disregard this message
Thanks man! Yeah read that too before on e-bay. Went to hondapartsunlimitid.com Thats were I plain on buying every thing I need for my rebuild gaskets, water pump, oil pump, timing belt, etc. I called my local Acura dealership and there prices were way higher
bcp7272
Oct 26, 2011 01:05 AM
