Please help DA Master Cly on a CRX?
Please help me out here i wanna know if the DA integra master cylinder will match up on my crx, i have a brake booster along with the DA master cyl, how can i make this work thanks a million!
Yes it will work you have to use the teh booster and master, I woul also highley suggest that you use the prop valve too along with rear disc if not already equiped
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ef-hatchcrap »</TD></TR><TR><TD CLASS="quote">Yes it will work you have to use the teh booster and master, I woul also highley suggest that you use the prop valve too along with rear disc if not already equiped</TD></TR></TABLE>
Nice avatar, thats my buddy's car.
To the OP just use a 4 door ex civic master and your stock booster with the DA prop valve.
It will work using the DA brake booster, no problem.
In my 88 CRX, I went with the DA MC and BB, I used a 90-91 CRX Si prop valve. I have front 96 Integra GSR brakes and 90-91 CRX Si rear disc brakes.
thanks alot, this was a big question i had for a while especially with my motors quickness i need stopping power for sure!
djnikko
12
Dec 8, 2006 12:50 PM
motore
18
Nov 19, 2003 07:33 PM
