HELP PLEASE!! Progress Sway Bar Question..
Old Aug 14, 2008 | 06:31 PM
mitcho's Avatar
Default HELP PLEASE!! Progress Sway Bar Question..
CORRECT ME IF IM WRONG! Do the Progress Front and Rear sway bar both go in the rear? the front sway bar is 27mm and the rear sway bar is 22mm. are they the same thing or what? The pictures posted for each are the same also. EXPLAIN PLEASE! THANKS!!!! Would i have to buy the endlinks or anything?
HERES A LINK TO CLUBRSX.COM and is what confuses me!!
http://www.clubrsx.com/cr/PRO-...nsion
Old Aug 14, 2008 | 06:53 PM
simonEp3's Avatar
Default Re: HELP PLEASE!! Progress Sway Bar Question.. (mitcho)
No they don't, I have both the front and rear on mine you keep the OEM endlinks, it comes with the sway bar and new bushings. It's a easy install and you can feel a difference. The one with the big umm... U shape in it goes in the front and goes in over your header/exhaust the rear just goes straight across the back, some people have had problems with their exhaust hitting it but mines done fine so far, guess I'll see when I install this new exhaust. Hope this helps.
Modified by simonEp3 at 8:38 PM 8/14/2008
Old Aug 15, 2008 | 05:33 PM
JesSi's Avatar
Default Re: HELP PLEASE!! Progress Sway Bar Question.. (simonEp3)
They aren't the same, CRSX just used the same picture for all of them.
Old Aug 20, 2008 | 12:34 PM
ivtecdriver's Avatar
Yea definitely not the same, great sway bars though!
Old Sep 2, 2008 | 01:21 PM
rsxpat's Avatar
Default Re: (ivtecdriver)
they are not the same, the front goes in front and the rear goes in the rear, but you may want to look into upgrading your factory end links as they will now be a week link. due to the extra stiffness in the new bars the factory end links may decide to bend or even break in half. i used the hotchkis adjustables and love em.
Old Sep 2, 2008 | 01:58 PM
simonEp3's Avatar
Default Re: (rsxpat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rsxpat &raquo;</TD></TR><TR><TD CLASS="quote">...look into upgrading your factory end links as they will now be a week link. due to the extra stiffness in the new bars the factory end links may decide to bend or even break in half. i used the hotchkis adjustables and love em.</TD></TR></TABLE>
I need to check into these also, where did you order your endlinks from?
Old Sep 4, 2008 | 11:47 AM
rsxpat's Avatar
Default Re: (simonEp3)
check out tirerack.com they have em in stock and for a good price.
djdownfawl
Honda Civic (2001 - 2005)
39
Dec 1, 2008 07:34 PM
shorejdm5
12
Dec 8, 2007 09:51 PM
2kstreetcivic
Apr 8, 2004 06:50 PM
Andrew 825SM
Jul 7, 2003 01:19 PM
