Integra & Bad alternator : Easiest route ?
Old Aug 14, 2008 | 05:41 PM
x4thGenCafe's Avatar
OF THE KINGS
Default Integra & Bad alternator : Easiest route ?
New to having an Integra and wanted to know your guys opinion on swappping out the alternator.
I thought I would be able to do it in like 10 minutes but soon found out that it isnt that easy.
Was thinking about taking the driver side axle out so i would have room to drop it below and get the new one in from the bottom but there has to be an easier way.
Any help would be great
Thanks guys
Old Aug 14, 2008 | 10:32 PM
OF THE KINGS
ill take it that noone with a teg on here does their own work ?
Old Aug 14, 2008 | 11:14 PM
egsleepercivic's Avatar
i just got teg so I don't know for sure but on my 92 civic with a B series, I got lucky and was able to just barely get it out without taking out the axle. So if you get lucky you might not have to take out the axle, but if the teg alt is even slightly larger than the sir2 alt you will be removing the axle
gl
Old Aug 15, 2008 | 06:36 AM
AWD Terror's Avatar
Default Re: (x4thGenCafe)
I had to take out the driver's side axle to get mine out.
Honda alternators = PITA
Old Aug 15, 2008 | 06:48 AM
OF THE KINGS
Default Re: (AWD Terror)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AWD Terror &raquo;</TD></TR><TR><TD CLASS="quote">
Honda alternators = PITA</TD></TR></TABLE>
Not really. Never had a problem doing it on my ef but thats an ef.
Looks like ill be tackling this again but with the car on jack stands.
thanks for the help and or suggestions dudes
Old Aug 15, 2008 | 08:29 PM
TBOGSR's Avatar
I just did mine on my 94 GSR and I started to take out the driver side half shaft, but then found a easier way to do it...
There is a bar right in front of the steering rack that is held in by 4 bolts(2 on each side) if you remove the bolts you can pull on the passenger side of the bar and wedge it up out of the way so that it gives you enough space to pull the alternator out from the bottom. You have to remove the battery tray to get the bolts on the passenger side. It takes a few long extentions to do it but it is much easier than pulling the half shaft...
I can take pics of it if you need them..
Old Aug 15, 2008 | 09:13 PM
OF THE KINGS
Default Re: (TBOGSR)
ya pics would be great.
you wouldnt happen to know a kid Nick would ya ?
I think he lives in the orange park area also.
shiit you might even know me . .
x4thGenCafe = Xavier ?
Old Aug 16, 2008 | 04:58 AM
TBOGSR's Avatar
Naaaa I don't know him..
I recently got back in the scene, plus I am a little older than you guys (34).
But I am always up for meeting new people and making new friends..
I'll see about getting you some pics this morning..
Old Aug 16, 2008 | 05:32 AM
TBOGSR's Avatar
Here you go...
http://www.hatunerz.com/other/pics/bar/
Look at pics 005 013 and 015 I have highlighted the items.
The driverside ones are directly below the brake booster. and the passenger side is directly below the charcole canister.
Once you got the 4 bolts out, goto the passenger side and pull the bar up and towards the front of the car. Its not gonna come out of the car, you are just going to move it around to get it out of your way.
Remove the alternator and maneuver it over to the center of the car, the point that it will drop out will be next to your exaust on the other side of the intermediate shaft end.
I think I explained it well enough (hopefully). If not give me a call and I'll explain it better 904-312-1462
Old Aug 16, 2008 | 05:51 PM
TBOGSR's Avatar
Did this help ?
Old Aug 16, 2008 | 06:00 PM
OF THE KINGS
not reallly
a friend is supposed to help me out tomorrow and he said he was gonna try and take the t bracket out to get the alternator out.
if anything ill call you if we Really need help
Thanks man
Old May 9, 2009 | 10:36 AM
khellapeter's Avatar
Default Re: Integra & Bad alternator : Easiest route ?
hey man i would like those pictures
Old May 9, 2009 | 12:30 PM
redflaredcrx90's Avatar
no ned to take out axle on a civic or integra jack up car looen 12 mm nut on the bottow reaket on alt and the the top to . theres is enough roo the pull it thur between the mid shaft and streering rack
Old May 9, 2009 | 12:49 PM
stocker2shocker91's Avatar
I requested a short story for a title.
x2
RanCRX
Jun 1, 2009 08:16 PM
mystikteg92
Jul 11, 2004 11:04 AM
smokey2.0
Feb 10, 2003 08:31 PM
Nameless RB26
Nov 17, 2002 08:21 PM
unKnown
Oct 12, 2001 09:15 AM
