My EJ8 Sedan
Old Aug 14, 2008 | 03:05 PM
Shocka1998LX's Avatar
Default My EJ6 Sedan
I still have alot of work to do on this baby, but considering never having a full time job and being stuck in college forever.. I think I'm doing alright. I've been doing alot of restoration on this thing because as fate has it, its been through alot of damage.
Initially it was sporting a Turbo D16, but has since evolved.
ViS Racing OEM Carbon Fiber Hood on the way
Parts on the list "to buy" in future:
Nardi Twin Steering Wheel
Function 7 LCA's
ASR Subframe reinforcement + 24mm swaybar
PasswordJDM c/f spark plug cover
JDMShit CTR style lip/rear lip combo
Skunk2 pro series intake manifold
Skunk2 Valvetrain & Cam Gears
CTR cams
Really need some black Recaros too but.. I'm poor
Parts now:
JDM B20 Block
USDM B18C Head
OBD1 conversion, chipped p28
Golden Eagle Dowel Pins
Cometic Head Gasket
Greddy Sandwich Plate
Greddy Oil Line and Fittings
ARP Head Studs
ARP Rod Bolts
GSR Water Pump
Hytech replica Tri-Y header
JIC Magic front strut tower bar
red valve cover
mugen oil cap
spoon sports radiator cap
spoon sports resevoir covers
short ram intake
92-95 civic polished alum radiator
Magnaflow high flow cat
Magnaflow 2.5" resonator
Twin loop muffler 2.5"
99-00 Civic Si gauge cluster
99-00 hatch cup holder
painted interior (black)
JDMShit Type R Style headlights
Shaved and plugged rear emblems
96-98 coupe grill
Integra rear disc brakes
99-00 Si 4040 Prop valve
ITR brake booster
ITR brake master cylinder (1")
H&R Race Springs (2.5" front/2.25" rear)
Tokico Illumina Struts 5-way adjustable
Omni Power Front UCA's (Camber)
Omni Power Rear Camber Kits
15x6.5" Rota Slipstreams
BFGoodrich gForce Sport 205/50/15 tires
Pioneer head unit and speakers
JL Audio 12" W3V3
JL Audio 300/2 Amplifier
Viper Alarm
I have alot more planned for the car but until money allows.. it'll always be slated with the "needs more work" phrase
Modified by Shocka1998LX at 4:58 PM 9/8/2008
Modified by Shocka1998LX at 4:27 AM 9/11/2008
Modified by Shocka1998LX at 6:40 PM 9/11/2008
Modified by Shocka1998LX at 2:55 AM 9/12/2008
Modified by Shocka1998LX at 1:01 AM 10/7/2008
Modified by Shocka1998LX at 2:32 PM 10/14/2008
Old Sep 5, 2008 | 10:48 AM
Spoon resevoir covers came in today.
I got the JL W3V3 w/ grill into a box, put down the wiring kit and mounted the amp. Everything was great until a trunk leak let moisture into the trunk and the amp blew up. Well, either that or some wiring came loose somewhere because the amp wont turn on. I'm going to assume the worst though.
How ideal is it to get a trunk leak fixed? Especially with any frame misalignments (car was in a major wreck once before). I mean are there shops out there that do custom weatherstripping? Other than that.. my only choice is to let the rear seats down when it rains.
Also, I think I'm dealing with a blown shock. It's not a CV axle. Can you get Tokicos by the shock or do you have to replace the whole setup?
Anyway, everything was shaping out nicely until this came up. Seibon hood was about to be on the way :X
Vanity plate idea:
"GSR 4DR"
"GSR4ME"
"B18C4DR"
"1POINT8"
Old Sep 5, 2008 | 09:09 PM
qwk db8's Avatar
Default Re: (Shocka1998LX)
did you just post a pick of a amp on a sofa....lol
Old Sep 6, 2008 | 12:10 AM
Scotty Dosent Know's Avatar
Default Re: (qwk db8)
LOL @ custom weather striping
Old Sep 6, 2008 | 06:14 AM
lol it doesn't hurt to ask, that mf'ing leak is bs
Old Sep 6, 2008 | 04:18 PM
custom weather stripping. complete.
I felt the lines between the trunk door and the rear quarter panel, one side of the trunk door was high. I did a leak test by having someone in the trunk with a flashlight while I hosed down my trunk. Found two leak spots. In order to compensate for the fat spaces between the trunk and the quarter panel, I took off the trunk weather stripping and I used some old ground wire and pushed it down into the crevice where it attaches. This raised the weatherstripping a perfect amount.
Then I found another space where some welding had been done (body repair), and it is rusting through. I put some silicon sealant over the holes for a temporary fix, but I'm going to let a body shop bondo it back together and repaint it. While I'm there, I'll get the rear bumper replaced and a rear lip put on.
Trunk leak project almost finished. Hopefully my amp isn't fried so I can get back to having some nice bump in the trunk.
Put down those spoon resevoir covers, they look hot, and just need some blue NGK plug wires to match. It's time to do the dist cap, plugs, and air filter anyway. Another CEL came up today but I'll have that cleared tomorrow and she'll be running strong again. Also pulled off the exhaust manifold heat shield today, to repaint it aluminum, as well as the bolts.
Horray for a prettier engine bay.
Old Sep 7, 2008 | 12:46 PM
With some TLC, polishing compound, spoon covers, repainted heat shield, new air filter, and spoon radiator cap, things look alot nicer! And my sub/amp installed sitting in the backseat while I work on my trunk leak.
Old Sep 7, 2008 | 01:35 PM
Caretaker's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Shocka1998LX &raquo;</TD></TR><TR><TD CLASS="quote">
Vanity plate idea:
"GSR 4DR"
"GSR4ME"
"B18C4DR"
"1POINT8"</TD></TR></TABLE>
car looks clean. how about GSRAWR?
Old Sep 7, 2008 | 04:59 PM
GSRAWR haha...that's sick. I thought about getting "B18 EJ6" or "B18C EJ" but I like that GSRAWR.
Tomorrow scheduling an appointment with the bodyshop to get my rear bumper repaired (cracked) and repainted. Also getting them to repair the inside of my trunk where some rust has accumulated causing some leakage.
Also placing an order for a new Tokico Illumina shock for my rear passenger side. That **** is blown :sigh:
Any suggestions for a rear strut tower bar?
Old Sep 8, 2008 | 09:00 PM
subwoofer is a go again! my wiring harness was faulty.
Old Sep 9, 2008 | 09:15 AM
car's at the body shop now getting the trunk jam redone. It'll be out tomorrow afternoon and be ready for me to clear the CEL and take a look at the rear passenger shock/spring setup and see what I need to replace.
Old Sep 10, 2008 | 10:42 AM
I just ordered abunch of stickers.
white 6th gen SHOCKER
white I hate speedbumps
white honda-tech.com
brushed silver DOHC VTEC x2
oh and an audi 1.8 emblem
I need eat-sleep-honda and team ej6 and I'll be good to go.
Old Sep 10, 2008 | 11:42 AM
Agent_EM1's Avatar
Default Re: My EJ6 Sedan (Shocka1998LX)
Nice
Old Sep 10, 2008 | 07:24 PM
for the side of the car where the scuff mark is I have a "stupid hurts" bandaid until I can get to the body shop
Old Sep 11, 2008 | 09:55 AM
I wonder how absolute polish 16x7 rota JMAG's or royal black GT3's would look. Instead of the gunmetal 15x6.5 slipstreams
Old Sep 11, 2008 | 11:55 AM
If I had money right now, I'd blow it on:
Hytech Tri-Y replica header (a/c compatible)
Skunk2 Pro Stage 2 cams
Skunk2 cam gears
Skunk2 valvetrain
Skunk2 intake manifold
Hondata S300
PasswordJDM cooling plate
w00t, but alas I am broke. Thanks ViS!
Old Sep 11, 2008 | 05:09 PM
Got my car back from the bodyshop, trunk leak is fixed. Now it's time to clear the CEL, replace rear passenger shock.
Old Sep 11, 2008 | 05:34 PM
just.me.ek5's Avatar
thats a preety sweet sedan there.
Old Sep 11, 2008 | 05:35 PM
gen2fanatic's Avatar
Default Re: (just.me.ek5)
Car looks pretty good. I like the "1POINT8" tag idea.
Old Sep 12, 2008 | 11:36 AM
Quad-Damage's Avatar
Default Re: (gen2fanatic)
looks good
Old Sep 13, 2008 | 09:23 AM
someone needs to donate me an aftermarket b-series header
Old Sep 13, 2008 | 02:30 PM
New pictures today:
Old Sep 13, 2008 | 04:58 PM
kotic's Avatar
^ more pics of the dog driving
Old Sep 14, 2008 | 12:38 AM
she only drives when I hop out of the car
Old Sep 15, 2008 | 03:04 PM
so I have some bad news, my GSR threw a rod or bearing today. I think my oil pump went bad without me knowing.
I guess it's time for B20/vtec.....
p.s. I am so pissed off.
