Possible Blown Head Gasket? Need Help! <Searched>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by steveteggy92 »</TD></TR><TR><TD CLASS="quote">Could take out the thermostat and see if your bottom hose gets hot.</TD></TR></TABLE>
In that case it would definitely get hot because there is nothing blocking the coolant...........
Running without a Thermostat is not the best idea. I just figure that a blown head gasket would keep pushing compression/air into the coolant system which creates air bubbles and does not allow the thermostat to open.
this is exactly wat i am going thru with my d16z6. i have changed the thermostat already. took the radiator out to pressure test it. the bottom hose remains cold, whereas the top hose is hot. cud this be a water pump? how do i bleed my coolant system. im sure i don't have any air tho. wat else cud be the issue. please help.
Mods, please delete this thread!
Problem was fixed. Changed the head gasket, it was in fact blown, had a small leak around cylinder 4.
panchlow
May 2, 2011 05:06 PM
DUKE LADUKE
Jun 21, 2010 05:33 PM
