B16 won't start on OBD1 conversion..
I first had problem with the engine harness that was converted to OBD1, so I decided to reuse my stock OBD0 89 HF engine harness with a low impedence fuel injector + the resistor Box. The distributor I’m using is a 95 GSR and it is connected with the OBD0 to OBD1 distributor adapter. I now have spark and fuel but the motor won’t fire up. I scratch my head and decide to run it OBD0 with a PR3 ECU and TD22U Distributor and it fire up. Of course it’s running rough because I have the 4 wire O2 sensor instead of 2 1 wire O2 sensor but what makes my OBD1 conversion not fire UP? I have a good working USDM P30 ECU (already tested on my friends car) and a brand new VTEC distributor that was also tested in my friends B16. For the ECU jumper harness I purchased it from Locashracing.com http://locashracing.com/store/...id=39
I’m a little lost and I really want my CRX pass the California REF. Any help will be grateful.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by x4thGenCafe »</TD></TR><TR><TD CLASS="quote">you have to mpfi that harness dont you ?</TD></TR></TABLE>
Thats if you have a DX. SI and HF is already MPFI.
Shoot I'm actually thinking about pulling my stuff, don't want to get caught. I mean if you get caught, what happens if you can't get a ref ticket? Anyways good luck with the swap, wish I could offer assistance on your issues. By the way did you ever find the GSR timing cover?
Man this is pissing me off. I switch the computer and the distributor to OBD0, it fires up in one try. Now i'm just thinking my jumper harness is bad or something.
I switch the fuel injector with a OBD1 and remove the resister box but still won't fire up. I mean it's trying to start and if it does, it only stays on for about a second.
Modified by FOMULA91 at 4:42 PM 8/15/2008
OK solve the Problem and the damn ecu jumper harness was bad. I tested out with the another harness from Rywire.com and it fired up in one try.
I guess DON'T buy from locashracing.com
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FOMULA91 »</TD></TR><TR><TD CLASS="quote">I guess DON'T buy from locashracing.com
I bet locashracing has been doing obd1 conversions since before you were legal to drive.
Sounds like a case of '**** happens'.
</TD></TR></TABLE>I bet locashracing has been doing obd1 conversions since before you were legal to drive.
91integra_rubio
Engine Management and Tuning
Mar 27, 2009 05:53 PM
Fezzie
Aug 31, 2006 05:40 AM
