b20 overloading with fuel when more than 3/4 throttle
Old Aug 13, 2008 | 07:34 PM
slob20ef's Avatar
Default b20 overloading with fuel when more than 3/4 throttle
I have a b20 in my hatch and since i converted to obd1 its overloading with fuel when im about three quarters thorttle or more, im not sure why, maybe its because of going from low voltage injectors to the high obd1's. I have an o2 sensor in it but im not sure its working because still throwing check engine light. Just trying to figure this out, or im going to start turning down my fuel tables till it stops
Old Aug 13, 2008 | 08:33 PM
crxfreak1117's Avatar
Default Re: b20 overloading with fuel when more than 3/4 throttle (slob20ef)
how about you check your codes first
Old Aug 13, 2008 | 08:34 PM
slob20ef's Avatar
Default Re: b20 overloading with fuel when more than 3/4 throttle (crxfreak1117)
i havent looked into how to do it i was told i have to jump a wire to somewere and it completes a circuit, can u clairify?
Old Aug 13, 2008 | 08:44 PM
slob20ef's Avatar
well i know on eg u pull the two pin connector down and jump a wire to complete that circuit, but i have an obd0 hatch with a jumper harness and is converted to obd1
Old Aug 13, 2008 | 08:47 PM
yes you have to jump 2 wires together its the orange and blue wires that i have to jump on the jumper harness then it should flash the codes on your check engine light
Old Aug 13, 2008 | 08:55 PM
slob20ef's Avatar
ok thanks alot, now with my jumper harness most pin to pin wires are black but there is a clip coming off which is color coated and i know runs vtec, o2, knock sensor and some others, so just find those two wires out of that bundle and jump them? thanks
Old Aug 13, 2008 | 09:02 PM
that is correct
Old Aug 14, 2008 | 09:01 AM
slob20ef's Avatar
jumped them and did nothing
Old Aug 14, 2008 | 09:18 AM
did u do it with the key in the on position not runnin but in the second on position
Old Aug 20, 2008 | 05:35 PM
slob20ef's Avatar
yes i did and it simply did nothing..
spoon93
13
Dec 31, 2011 06:59 AM
turboef90
May 11, 2009 02:43 PM
91highryda
Oct 6, 2007 08:24 AM
si0385.
Mar 31, 2006 12:33 PM
turborex2
Jul 22, 2005 07:13 AM
