1.8 LS-V dyno sheet
Tuned by Abel Racing in OKC on Crome
Edelbrock header w/ 2.5 mod
2.5 full custom mandrel bent piping
No cat
No resonator
Vibrant muffler
B18b block
Pr3 b16 pistons
Stock LS rods w/ ARP rod bolts
Stock crank
DIY PnP GSR head w/ 3 angle v/job
OBD2 Prelude 290cc injectors
Walbro 190 fuel pump
OEM itr valves
Supertech valves springs
Crower chrome moly retainers
Blox B cams (same as sk2st2)
Golden Eagle cam gears (set a zero)
AEBS IM (gasket matched)
Performance 68mm TB
3in Ebay short ram w/ ebay filter FTW
Short and simple.
No cat
No resonator
Vibrant muffler
B18b block
Pr3 b16 pistons
Stock crank
OEM itr valves
Performance 68mm TB
Short and simple.
Did you play with the cam gears at all or just leave em zero'd out?
If you didn't touch them I'd say there could be a few more poines in your setup.
I'd also try a larger exhaust and a better header. You'll break 200whp easy with those additions.
good numbers and build
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BMo Tuning »</TD></TR><TR><TD CLASS="quote">Did you play with the cam gears at all or just leave em zero'd out?
The cam gears were adjusted/played with but we couldnt get any HP out of it in the time span that I had.
</TD></TR></TABLE>The cam gears were adjusted/played with but we couldnt get any HP out of it in the time span that I had.
Nisif
47
Sep 21, 2010 08:29 PM
nicklk
44
Jun 20, 2005 07:15 PM
hayabusa160
42
Mar 8, 2005 04:14 PM
