I need swap help bad NO SPARK
Old Aug 13, 2008 | 05:59 PM
crxnonvtec's Avatar
Default I need swap help bad NO SPARK
I have a crx with a d15b2 auto I just swapped out I followed the dpfi to mpfi instructions and rewired the car. everything works except I have no spark anyone else have this prob?? and yes there is power goin to the distrubtor
Old Aug 13, 2008 | 07:54 PM
beige89civic's Avatar
* B A N N E D *
Default Re: I need swap help bad NO SPARK (crxnonvtec)
Is your rotor set screw in place? See if it fell off. What about coil?
Old Aug 14, 2008 | 07:19 AM
x4thGenCafe's Avatar
OF THE KINGS
re check your wiring. I know you think its right but think about it. if its not working properly its not right. Run through ALL the wiring you did and recheck
Old Aug 14, 2008 | 07:48 AM
crxnonvtec's Avatar
Default Re: (x4thGenCafe)
the wiring is 100% correct its been checked and rechecked but the dizzy came right off a car so idk what it could be still ....Im still workin on it I need to get to honda day in NJ
hahahaha
Old Aug 14, 2008 | 07:56 AM
placid888's Avatar
chech the coil(inside distributor) for resistance
Old Aug 14, 2008 | 09:20 AM
phoenix_iii's Avatar
From: Close to West Chester, PA, United States of America
Default Re: I need swap help bad NO SPARK (placid888)
You don't know if the Distrubtor is good... I think that's how you spelled it. heh
Old Aug 14, 2008 | 09:32 AM
KraziCivicSi's Avatar
Default Re: I need swap help bad NO SPARK (phoenix_iii)
did u check grounds? check your grounds again, what dizzy did you use? if you used a pdfi dizzy with a mpfi swap...it wint work.
Old Aug 14, 2008 | 09:48 AM
jlicrx's Avatar
make sure you have the ground wire from the engine harness connected at the thermostat housing
Old Aug 19, 2008 | 03:29 PM
crxnonvtec's Avatar
Default Re: I need swap help bad NO SPARK (jlicrx)
just traced it to the e.l.d and now it says check the alternator control system but I dont know what it is.
nycpatron
Nov 17, 2012 08:20 AM
thedudefromjerz
Feb 17, 2008 06:33 PM
DeviousCTR
Apr 25, 2006 07:02 PM
thrty8street
15
Apr 18, 2006 02:46 PM
90crxb16a
Jul 11, 2003 03:00 PM
