getting nervous close to swap time
getting close to swap time so pre swap jitters are coming on...i have a b16a from hmotorsonline.com that's going in a 1990 4dr ex
i'm using this article, http://www.crxresource.org/mod...d=134
but i still have a few questions. i figured some of the people here will know the answers, so here i go.....
i'm pretty sure i need throttle cable off a 90-93 integra, but what about clutch cable or tranny mount. i bought the wiring sub-harness so will i need to do anything special or is it plug and play...also my car was previously wrecked on the drivers side and i think i might have dx steering knuckles and hubs on that side so should i get some from and integra and swap them both or does anyone have an extra drivers side steering knuckle/hub for an ex? well that's all that comes to mind right now, if you have any other knowledge you would like to kick down please do...right now all i have is what comes with the full swap from hmotorsonline
ya you need the da throttle cable. you can use your stock clutch cable or the teg one doesnt matter. not sure what you mean by sub harness but you gota use a stock engine harness for the car. you need aftermarket mounts for the motor if your talking about the rear t bracket you get that one off a da teg. the axles will work just fine in a dx hub its the same size hole as si ex da teg the only ones that are smaller are hf and std 4 speed. dont be scared its easy thats why so many people have hondas.
hey thanks!! yah i got hasport mounts i was talking about the bracket you answered everything i needed to know. the sub harness is for the v-tec connection. thanks a bunch
Adrian G. Aka JDMonkey
Nov 3, 2005 08:36 AM
