95 gsr??????ques about turbo
now can somebody take the time and tell me where to start if i want to make it turbo.....and i mean all out but wit a buget set at 3500.00 hundred......question??????like what kinda.....pistons..rods..crank....vavles springs...i have my mind set on a turbo already now thats the buget i have for the motor???????thk
idealistically, you dont need to rebuild your motor for boost. a b18c1 will handle it very nicely. you can get a very nice kit for 3500. try SCtuned here in philly. they sell peakboost kits.
however, if you really want to rebuild, due to bad compression or whatever, you should take the time and do your research and budget yourself for that first, with plans for boost later.
Modified by HONDRETTI at 7:05 PM 8/13/2008
Modified by HONDRETTI at 7:13 PM 8/13/2008
so just put a turbo on a stock motor??????how much boost you think i can run wit stock internals...to be on the safe side??????thk again
Modified by laboyon at 4:17 PM 8/13/2008
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by laboyon »</TD></TR><TR><TD CLASS="quote">so just put a turbo on a stock motor??????</TD></TR></TABLE>
yes. honda motors handle boost very well. how many miles does your motor have?
its a greddy turbo kit they want about 27hundred for it...is there any cheaper out there that will give me the same effects......and what about cam gears.....fuel....spark....they need up graded also right??????thanks you guys are a big help!!!!!!!! i thought i needed to change alot for a turbo hook up...but i guess not!!!!!!
Modified by laboyon at 5:44 PM 8/13/2008
you need some kind of engine management and probably headstuds would be recomended. i am also in the market and have been doing some research on the subject. I still am looking for more info so if anyone has some good tips, enlighten please!
edit... i searched and this is what i came up with
dont go by boost numbers alone - different turbos make different hp improvements
you can boost 20psi out of a small *** turbo and gain 50whp or you can boost 5psi out of a big turbo and gain 100whp.
generally, B-series with turbo's start breaking major parts around 300whp.
of course, there are e-racers that push more, but every motor is different
like spec R said - you cant go by psi, different size turbos put out different power at the same psi.
you gotta go by whp, *PERSONALLY* (notice i dont mean this is what it HAS to be) i wouldnt go over 300whp on a stock block.
at this amount of power you wont have to upgrade anything really, besides injectors, fuel pump, and get yourself some nice colder spark plugs.
you should really do some deep research bro, it sounds like youre not very informed yet, make sure you know what your getting yourself into before jumping into the boost wagon, stuff starts breaking faster
added - oh yeah, TUNE TUNE TUNE!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TehGhett0P1mp »</TD></TR><TR><TD CLASS="quote">Please go read before you blow your **** up =/</TD></TR></TABLE>
hook up some good links??
~i have been searching for a good informative peice on this subject but have mainly only found bits and peices of info
dam if i blow **** up i guess ill just have to start all over again right...jus asking for a little help.......not a pro here just trying to have fun.....you know what i mean...
the kit probably will not include any fuel system upgrades that YOU WILL need. Fuel pump, And bigger injectors 440cc at the very minimum.
for good links Go to the Forced Induction forum and click on FAQ
The greddy kit comes with a e-manage engine management.. not the best in the world, but enough to run that greddy kit.. Also it comes with 310cc injectors.
just make sure you get it properly tuned.. Tunning is everything in a boosted car, I would suggest asking your tuner to give you a "conservative" tune. Alot of tuners will try and get you at max HP without keeping in mind that it is a daily driven car and that will reduce the longivity of the motor.
I agree with rick, set your goal on the power you want to make, not on a PSI. I have seen stock GSR at 380-400 whp but the reliability at this HP is going to be limited.. But with that Greddy kit 400whp will be about the limits of that turbo anyways..
bro if i was you i would save the 3500 and go with a custom kit. I just turbo chared my teg for 2600. that is with a HUGE fmic, 700 injectors, tail waistegate, t3/t4 turbo, hks blow off valve the manifold EVERYTHING you need to boost PLUS hondata s300. smokin WS6 and takin Z06
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by laboyon »</TD></TR><TR><TD CLASS="quote">whats going on rick???????whats your suggestion????</TD></TR></TABLE>
see below
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TBOGSR »</TD></TR><TR><TD CLASS="quote">I agree with rick, set your goal on the power you want to make, not on a PSI. I have seen stock GSR at 380-400 whp but the reliability at this HP is going to be limited.. But with that Greddy kit 400whp will be about the limits of that turbo anyways.. </TD></TR></TABLE>
Right on bro.
Please look up the forced induction forum. There's a vast amount of information on there, I learned ALOT of things. Good luck.
