P2T to P73 b18c problem
Old Aug 13, 2008 | 12:49 PM
MPT23's Avatar
Default P2T to P73 b18c problem
I have a b18c swap in my 99 civic si, i am currently using a p2t ecu but i purchased a p73 ecu and only 2 of the 3 plugs fit does anyone know if there is a conversion harness that i can purchase? also i heard that there is a vtec controll wire that needs to be hooked up? Any help or suggestions would be great.
Old Aug 13, 2008 | 02:18 PM
Relic1's Avatar
your car = OBD2b
P73 = OBD2a (most likely since the OBD2b versions had the immobilizer)
your SI would have all the wires you need for the B18C. (unless it's a GSR and not an ITR)
Old Aug 13, 2008 | 03:48 PM
MPT23's Avatar
Default Re: (Relic1)
Thanks for the help I guess i better purchase the conversion harness off booslang. Is there an easy way to make sure its an itr and not a gsr.
Old Aug 13, 2008 | 09:19 PM
Relic1's Avatar
shape of the intake manifold, the ITR curves up, GSR curves down. (from the head to the plenum and throttle body)
Cupajoe
Jul 15, 2017 07:29 PM
GeeUK
Dec 8, 2011 02:49 PM
lowcrx1
Sep 14, 2008 06:01 PM
c-townekhatch
Dec 11, 2006 05:46 PM
