what rpm do u guys launch at for a 4th gen???
Old Jul 22, 2002 | 11:11 PM
Tx92AccordExD's Avatar
Default what rpm do u guys launch at for a 4th gen???
what rpm do u guys launch at for 1/4?
i was wondering what rpms do u guys launch at. just took my car to the track and clock a 16.6.
heres my times
60 ft.= 2.519
1/8 et= 10.681
1/8 mph= 66.29
1/4 et= 16.629
1/4 mph= 83.17
is that good 60 ft times for a 4th gen accord??
what about 1/8 mile?
Old Jul 22, 2002 | 11:16 PM
Accord94DX's Avatar
Default Re: what rpm do u guys launch at for a 4th gen??? (Tx92AccordExD)
your 60 foots suck. Your cars is heavy and slow. Learn to drive, get a faster car. There.
Old Jul 23, 2002 | 12:10 AM
Default Re: what rpm do u guys launch at for a 4th gen??? (Accord94DX)
whats a good 60ft time for 5 speed accords??
Old Jul 23, 2002 | 08:38 AM
Ludehrt's Avatar
Back in the days...
I use to have 215-60-15s, I use to pull 2.3 60s with 25psi if air. I launched at about 3.2-3.5k- while feathering the gas.
I then switched to Nitto 555s Drag radials 205-50s I pulled low 2.1s. I launced at about 3.5k-3.8k- while feathering the gas
Just an FYI- Good 60ft times MAKE good 1/4 mile times. Shoot for a 2.3.
Old Jul 23, 2002 | 09:05 AM
2point6's Avatar
Dude why?
Old Jul 23, 2002 | 09:10 AM
smokin rubber's Avatar
Default Re: what rpm do u guys launch at for a 4th gen??? (2point6)
I usually got 2.3 60ft and have a couple 2.2 , I would use the smallest wheel you have, and run ~30 in the left and 27 in the right. This is because the right tire spins more normally. Do you have any mods to the car?
2point6's Avatar
heres my times
60 ft.= 2.519
1/8 et= 10.681
1/8 mph= 66.29
1/4 et= 16.629
1/4 mph= 83.17
All you need is practice. If you can afford to make improvements on the car, start with the basics (i,h,e) and then work on the suspension. I believe you can drop your 60ft time significantly to around 2.1 with little work. This will help with your E.T. of course. Stick around (don't get scared off by the ones who don't offer help) and ask questions. I have been racing my 4th gen for a while now and have been able to pull 1.8 60's with a fully equipped car. (no, the engine isn't a stock f22 however)
Old Jul 23, 2002 | 09:14 AM
John's Avatar
New User
Or a stock H22 for that matter either.
Old Jul 23, 2002 | 11:14 AM
Ludehrt's Avatar
Default Re: what rpm do u guys launch at for a 4th gen??? (DunReit)
You can still pull decent times/60ft with a slightly moded f block.
I have been Dragin my 4th F-block gen for about 3 years now. I went from running 17.3/2.5 maiden run to running a 14.999/2.1.
With the new H22....we will see what times I can pull
Like 2.6 said. Lots of Seat also needs to be added to the equation if you want to run good times.
Dont forget to add some suspension mods: Konis/Ground Controls with a good spring rate (idealy 350Fr-500R)
Adjust front suspension to remove as much camber as possible
Remove weight from rear part of car. (yes that means those bi-plane wings)
Get a set of Drag radials/Slicks for the track
..and Practice,Practice,Practice
Laterz
RichardV
Altered4
[Modified by Ludehrt, 8:20 PM 7/23/2002]
Old Jul 23, 2002 | 11:35 AM
4doorH22's Avatar
Default Re: what rpm do u guys launch at for a 4th gen??? (Ludehrt)
14.999/2.1 for a 4th gen that's pretty quick.
I'm hoping this is on slicks with a lot of weight reduction?
Old Jul 23, 2002 | 12:44 PM
Ludehrt's Avatar
Default Re: what rpm do u guys launch at for a 4th gen??? (4doorH22)
Ran this time with:
92 Accord Ex Coupe 5spd-F22a6 (F22 for sale by the way....Best offer)
Open header, Open Intake,Advanced timing, removed PS belt
Nitto 555s Drag radials, Weight reduction, Car Weighs 2480 (w/o Driver)
Basicly on "free mods" and lots of seat time.
Heres the slip
Here some old outdated pics if ya want to check them out
http://www.geocities.com/ludehrt92/
Laterz
RichardV
ALtered4
[Modified by Ludehrt, 10:00 PM 7/23/2002]
Old Jul 23, 2002 | 02:08 PM
4doorH22's Avatar
That's great man. I've got 500 lbs on you easy also w/o driver (and I'm only 140 lbs).
I'll scan in my time slip.
Old Jul 23, 2002 | 04:07 PM
CD8's Avatar
CD8
hey ludehrt! ill buy your f22! pfffft! yeah right
2 weeks away!
Old Jul 24, 2002 | 10:25 AM
Ludehrt's Avatar
Default Re: what rpm do u guys launch at for a 4th gen??? (exaccord)
CODE WORD
H DUECE IS ON THE LOOSE
Laterz
RichardV
Altered4
Mr.2.2 hatch
Nov 5, 2004 06:10 AM
elmo244
Oct 29, 2004 10:48 PM
B.
46
Jul 5, 2003 09:39 PM
KFL
Apr 20, 2003 03:16 PM
Kermit EK
Feb 21, 2003 04:02 AM
