FROM manual mirrors :to: JDM PW folding mirrors!! how to?
Old Aug 13, 2008 | 11:01 AM
teh Dirka's Avatar
Default FROM manual mirrors :to: JDM PW folding mirrors!! how to?
hey guys, i just bought some pwr folding mirrors of PW:JDM.com, it came with the mirrors, relay and switch, unfrtunatly the wires were cut... ne ways, idk how to instally them if i have a DX hatch, its got manual mirrors, and i dont know how to hook it up with the pwr folding ones.
ive searched and searched, but i cant find anything, and when i do,, the link is dead.
so please either point me in the right direction or just help me out! thanks guys!
Old Aug 13, 2008 | 12:51 PM
vietfella's Avatar
Default Re: FROM manual mirrors :to: JDM PW folding mirrors!! how to? (teh Dirka)
I guess you didn't search enough. but here's a wiring diagram.
cheers.
https://honda-tech.com/zerothread?id=2312002
https://honda-tech.com/zerothread?id=646714
Old Aug 13, 2008 | 06:30 PM
teh Dirka's Avatar
i actually found thoes, but i think that because my mirrors are manual, that i dont have that spot for power mirrors... am i wrong? does the dx hatch have a spot for pw mirrors, or did they modify the harnes to only have the certine things that each model for example, is the Si's harness diffrent then the DX harness?
Old Aug 13, 2008 | 08:56 PM
VTAC-KAT's Avatar
Default Re: (teh Dirka)
here is an image of your fusebox that i stole from here: https://honda-tech.com/zerothread?id=1716625
The green rectangle is where 5 aux + power outputs can be found. Use the one in the middle as it is only powered when your key is turned.
Since your car doesn't have power folding mirrors, you will have to wire them yourself.
I put powerfolding mirrors in my 93 dx hatch by following the wiring chart and getting power from the middle auxiliary. I used to have one manual mirror and now I have two powerfolding mirrors.
You will need both mirrors, the relay, and the switch. When you buy your componets, make sure they come with the harness. Mine came with a cut harness but I wired it back together in about two hours using that chart and the help of a friend.
The only downside to these mirrors is that they are designed for RHD vehicles. The angles and mirrors are different but I still am able to use them for driving. The left mirror needs to be positioned all the way to the right in able for them to work for me while driving.
RUCHO01
Apr 30, 2009 08:09 AM
91redteg
Sep 17, 2007 09:21 PM
Backk InTheDA
Dec 8, 2005 08:48 PM
b18c-1
Nov 2, 2005 04:56 PM
JdmCIVIC853
Feb 4, 2003 02:40 PM
