91 integ axles dont fit in hub(b16a0bd0)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackrocky »</TD></TR><TR><TD CLASS="quote">axles fit in the trans but not in the center hub. how can i make this work?</TD></TR></TABLE>
This wouldn't happen to be a 4 speed model would it?
If you have a 4 speed then you had a standard.
B series axles fit in both da hubs and dx/si hubs but not Standard 4 speed hubs.
If you have a standard then you need either dx or si knuckles or 90-93 DA knuckles. Don't forget to get the brakes with your knuckles.
Also using dx or si knuckles you still need to remove the dust rings off the axles.
From: Where the wild things are in, NY, United States of America
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackrocky »</TD></TR><TR><TD CLASS="quote">i think your incorrect. correct me if im wrong but i think i need a knuckle from a 90-93 knuckle</TD></TR></TABLE>
Go look at the faq at the top of the forum, this has been covered a couple times.
no, I'm not.
no, I'm not.
kaddi88
Apr 2, 2008 11:39 AM
omahaturbocivic
Nov 14, 2002 01:59 PM
