A/C ISSUE!!!
I have a B series swap in my civic with a/c hooked up. Everything was working for a while. Now the A/C doesn't work. I checked all the fuses and wiring and I can't find out whats wrong with it. The condenser fan turns on and the idle changes a bit when I try to turn it on, but no cold air. I don't think the compressor is turning on? Any suggestions on what the problem could be? It's starting to get pretty hot here in the bay area.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_SOHC »</TD></TR><TR><TD CLASS="quote">sounds like bad clutch in the compressor...</TD></TR></TABLE>
Before it went out. The a/c would turn on and off. Maybe you're right... Whats the solution for this? just replace the compressor?
ballinboosi
Honda Civic (2001 - 2005)
25
Aug 17, 2009 02:38 AM
