Balljoints and Alignment
I'm redoing my front end in preparation to get an alignment since I couldn't before because my upper ball joints and tie rod ends needed to be replaced.
For future reference, will my alignment go bad if I replace the lower ball joints later on?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OmarR »</TD></TR><TR><TD CLASS="quote">I'm redoing my front end in preparation to get an alignment since I couldn't before because my upper ball joints and tie rod ends needed to be replaced.
For future reference, will my alignment go bad if I replace the lower ball joints later on? </TD></TR></TABLE>
Yes, you will need to get your wheels re-aligned.
In all honesty- I wouldn't worry about it.
A bad ball joint is usually going to give you slop up and down- but in a static position on the alignment rack, it won't come into effect.
Tie rod replacement will need an alignment after for sure
...unless you're good at counting threads
PandaBear
Suspension & Brakes
Jul 22, 2006 08:26 AM
MiX
Dec 27, 2004 07:32 PM
