zc clutch kit on d16y7
getting a free exedy clutch kit with flywheel off a zc, ive heard it fits but i want to make sure that the zc clutch and flywheel will work on my d16y7 before i tear mine out. i believe they are the same since they both use d series tranys
BTW:
There will be different clutch spline counts depending on what year ZC you got the clutch from.
It also really depends on what tranny was attached to the ZC as well.
If the clutch came from an OBD1 VTEC ZC with a hydro tranny attached then yes it will work with your D16Y7.
If the clutch came from an older ZC with a cable tranny that's where it gets really dicey/uncertain. Early cable trannies had smaller spline counts than 92-up Civics.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sawedoffcoupe »</TD></TR><TR><TD CLASS="quote">the guy im getting it off says "obd1 sohc non vtec
hydro tranny,"
so im guessing it would work then?
Yes.
hydro tranny,"
Yes.
phatrick2332
Mar 31, 2004 06:11 AM
