ITR Cluster Temp. Gauge Gets Really Hot Sitting in Traffic
Old Aug 12, 2008 | 01:59 PM
integraslut78's Avatar
Default ITR Cluster Temp. Gauge Gets Really Hot Sitting in Traffic
So I have experienced this a few times, just wanted to see if anyone else has and maybe wgat they did to fix it. So I would be sitting in typical LA traffic and I would look down and my temp. gauge would be almost pinned in the red, it was hot but not over-heating hot. But when I would be able to move for a little bit all of a sudden the temp. gauge would go down to where it normally sits. My friend also had this problem over the weekend in his Civic with a CTR cluster. Has anyone experienced this and amybe knows how to fix it??? Thanks in advance.
Old Aug 12, 2008 | 03:03 PM
BlueIntegraBoy's Avatar
Default Re: ITR Cluster Temp. Gauge Gets Really Hot Sitting in Traffic (integraslut78)
Never had a problem. Maybe your temp sensor is bad.
Old Aug 12, 2008 | 04:00 PM
Default Re: ITR Cluster Temp. Gauge Gets Really Hot Sitting in Traffic (BlueIntegraBoy)
I figured if my thermostat was off it would be all the time not just when I'm in traffic...??? I'm really confused. No one has experienced this???
Old Aug 12, 2008 | 05:35 PM
Dogginator's Avatar
Daisy... Daisy...
If it is moving, I would suspect a real temperature issue. Is the cooling fan running when it is showing hot?
Old Aug 12, 2008 | 05:40 PM
b17rider's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integraslut78 &raquo;</TD></TR><TR><TD CLASS="quote">I figured if my thermostat was off it would be all the time not just when I'm in traffic...??? I'm really confused. No one has experienced this???</TD></TR></TABLE>
fan switch?
Old Aug 12, 2008 | 10:52 PM
Default Re: ITR Cluster Temp. Gauge Gets Really Hot Sitting in Traffic (Dogginator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator &raquo;</TD></TR><TR><TD CLASS="quote">If it is moving, I would suspect a real temperature issue. Is the cooling fan running when it is showing hot?</TD></TR></TABLE>
Yup the fan goes on exactly when it should that's what I thought, well actually I thought the fuse was blown for the fan, I was wrong.
Old Aug 13, 2008 | 01:09 AM
jcidio's Avatar
check coolant levels, and for any possible leaks.
Old Aug 13, 2008 | 10:35 AM
Default Re: (jcidio)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jcidio &raquo;</TD></TR><TR><TD CLASS="quote">check coolant levels, and for any possible leaks.</TD></TR></TABLE>
Thanks everyone for the responses... I will check out some things after work today.
klinster
Sep 23, 2009 04:19 PM
zippakilla
Feb 21, 2009 11:02 AM
klinster
Jan 17, 2009 01:08 PM
tuphatt
Jan 29, 2005 08:06 AM
