Car died last night on the fwy 1990 wagon
So i was going home last night hopped on the freeway and right when i got up to about 65-70 mph my car started bogging out like it was running out of gas..(which according to the needle it was ) so no biggie i had enough momentum to make it to the gas station , i try starting it up and it cranks and cranks and then it made like a small backfire poping noise as if the firing order was off.
So now that it has gas im wondering what could this be?
Im going to post a video of me trying to start it so you guys can hear it too.
the car is a 1990 civic wagon with about 283k newer block d15b with the stock head.
Also i checked the oil (which was just changed not to long ago and it was empty ) but the oil light that usually comes on wasnt on..
I've been having problems with starting the car sometimes mostly when its closer to empty , a friend of mine suggested since i always wait til its on empty to fill up that my fuel pump might be [freak]ed.
any suggestions or comments are welcome thanks !
like the person that replyed already. check for the fuel pump hum and answer back. if your car starts up no problem SOMETIMES, that means your fuel pump i probably going out soon
k u dont know what it sounds like, turn your key to the 2nd position. NOT ON, but right before it turns on. ull hear a click (main relay) and the check engine light should turn on while u hear a humming sound (fuel pump)
u getting the click and the hum?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bobjohnson »</TD></TR><TR><TD CLASS="quote">Check to make sure the rotor didnt fall off inside the dizzy.</TD></TR></TABLE>
i was going to suggest this. bet this is it...or at least rotor-related...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rbwdriven »</TD></TR><TR><TD CLASS="quote">actually check your rotor screw. the rotor still might be attached but the screw could of come out.</TD></TR></TABLE>
This happened to my boss's ED. Timing belt was worn so it jumped time. I did a cylinder leakage test and heard noise in the intake so I removed the head to find out that the valves didn't hit. Heard leakage though
. Put the distributor on and was losing spark. Removed the cap and the damn set screw fell off!! New rotor set screw and cap fired right up! Still can't believe a little set screw kicked my ***.
IneedBoostInTheCoupe
Aug 7, 2004 09:58 AM
Spooled1.6L
Feb 9, 2004 03:56 AM
