Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
slightly oversized rotors
Old Aug 11, 2008 | 08:06 PM
MV99-S's Avatar
Default slightly oversized rotors
there is no off the shelf application for my vehicle but wilwood has hats that will fit the problem is the rotor, the one that has the right width is .3 bigger than what I have but that size is .25 inches wider.
Would there be any reason the .3 inch bigger one would be a problem ?
There is also another minor but not deciding benefit that the taller rotor is 4 pounds lighter per
Old Aug 12, 2008 | 07:35 AM
ntegnifong's Avatar
Default Re: slightly oversized rotors (MV99-S)
Ive seen this on some cars. and if you use new pads they'll drag for the first couple miles. No big deal. helps get some heat in them!
Old Aug 12, 2008 | 04:57 PM
Justin3's Avatar
Default Re: slightly oversized rotors (ntegnifong)
A quarter inch is an awful lot in either direction especially in brakes where clearances can be tight as it is.
avgjoe
Suspension & Brakes
Aug 1, 2011 02:46 PM
shatchi
Jun 3, 2007 07:05 PM
mechengine
Apr 3, 2004 10:48 PM
itrsport.com
Jun 17, 2002 08:27 AM
sjasmund
11
Jun 1, 2002 06:13 PM
