what kind of axles will i need for a b16 swap?
Old Aug 11, 2008 | 06:42 PM
Type-R32's Avatar
Default what kind of axles will i need for a b16 swap?
what kind of axles will i need for a b16 swap, can any b series axleas work for an ef?
Old Aug 11, 2008 | 06:44 PM
Intocable's Avatar
Default Re: what kind of axles will i need for a b16 swap? (Type-R32)
what half shaft are you using?
Old Aug 11, 2008 | 07:34 PM
azazello's Avatar
i am using these ones:
http://raxles.com/
Old Aug 11, 2008 | 07:45 PM
vtec_ef8's Avatar
It usually depends on whether or not your using a hydro tranny or a cable tranny.
On my b16 swap thats a first gen b16 I use 91 integra axles non abs. for hydro I think its 94 and up integra
Old Aug 12, 2008 | 07:46 AM
Type-R32's Avatar
its a cable tranny, but iunno what kind of intermediate shaft it has but i think its of a jdm integra
Old Aug 12, 2008 | 11:03 AM
jlicrx's Avatar
Default Re: (Type-R32)
http://www.hasport.com/news/ar...2.htm
Old Aug 12, 2008 | 01:19 PM
Type-R32's Avatar
thanks, thats alot of info, how can i tell what car my engien came from?, its a b16a with a ys1 tranny with lsd?
Old Aug 12, 2008 | 01:22 PM
brandIZZLE!'s Avatar
R.I.P Little Brandon
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Type-R32 &raquo;</TD></TR><TR><TD CLASS="quote">thanks, thats alot of info, how can i tell what car my engien came from?, its a b16a with a ys1 tranny with lsd?</TD></TR></TABLE>
dont quote me but im pretty sure it came from an 88-91 hatch/crx from Japan.
Old Aug 12, 2008 | 01:47 PM
Type-R32's Avatar
oh ic, so that mean if i get 90-93 integra axles i will also need the intermediate shaft? it wont fit on the jdm crx/civic ishaft
Old Aug 12, 2008 | 10:09 PM
philkehn's Avatar
im sure the ys1 came in the integra xsi's... If you have a cable tranny you have to find out what kind of half shaft you have, if you have a b16 half shaft you have to use the shaft in inner joint from a 87-89 integra and the outer joint from a 90-93 integra..... If you have a integra half shaft you can use 90-93 integra axles on both ends.
Old Aug 13, 2008 | 10:37 AM
Type-R32's Avatar
Default Re: (philkehn)
oh ic, my engine came with the half shaft already, its just missing the axles, but i guess i could just use 90-93 integra axles if its off xsi, would automatic trans axles work on it too?
Old Aug 13, 2008 | 11:10 AM
gringo7718's Avatar
You need to match the axles to the half shaft. Identify your half shaft and then get the axles that work with that half shaft.
here is some more info. hope this info helps
http://crxcommunity.com/viewto...99ae5
SIR/Y1 half shaft is TOP, 90-93 Integra BOTTOM
The Y1/SiR intermediate shaft is stamped "SH3" above the female end, and the 90-93 Integra mid-shaft is stamped "SK7" in the same spot.
Old Aug 13, 2008 | 11:12 AM
gringo7718's Avatar
Default Re: (gringo7718)
PS: Learn to search on your own, I searched "B16 half shaft" on google and found this in under 30 seconds.
Old Aug 13, 2008 | 08:29 PM
Type-R32's Avatar
yeah lol, but ht is best place to get some help from the honda community
Old Aug 16, 2008 | 07:03 PM
Type-R32's Avatar
im kinda confused, people are saying its off SiRs and XSis, i read the code of the intemediate shafts female end and it was stamped sh3, also it was stamped sh6 on the very top. so what car did my engine really come out off?, i think its of an jdm SiR
Old Aug 17, 2008 | 11:35 AM
philkehn's Avatar
well if you have a ys1 tranny its most likely out of a xsi im sure.... so i would just buy the 90-93 axle see if it fits and if it does not fit go and buy the 87-89 axle and put the outer joint from the 90-93 on the shaft of the 87-89 and bravo.... either way your gonna need the 90-93 axle....
lilsicsoul
Mar 16, 2009 07:07 PM
hondateg10
Jan 14, 2008 03:36 PM
aznboi_2
Jul 13, 2006 06:10 AM
acydphryck
Mar 29, 2004 05:58 PM
drewlee
Oct 2, 2003 07:48 PM
