97+ prelude internal coils?
Old Aug 11, 2008 | 05:56 PM
dvp95's Avatar
Default 97+ prelude internal coils?
I have a jdm 98 h22a thats internal coil. I believe that all 97+ usdm preludes are external coil. Is there another car that I can use that is interchangeable or do I need to covert to an external coil using the 97+ usdm coil? Thanks
Old Aug 11, 2008 | 06:09 PM
mongtite's Avatar
Default Re: 97+ prelude internal coils? (dvp95)
U can convert the JDM to work externally or You convert your to internal, which even way U like, U can do it.
Old Aug 11, 2008 | 06:17 PM
dvp95's Avatar
Default Re: 97+ prelude internal coils? (mongtite)
If I want to keep my jdm as internal, which coil do I buy because the USDM is external on the 97+ preludes?
Old Aug 11, 2008 | 10:40 PM
mongtite's Avatar
I think U might want to make it a external, U can just switch out the distributor.
Old Aug 11, 2008 | 10:41 PM
mongtite's Avatar
I will let U know how this is done tomorrow.
Old Aug 11, 2008 | 10:50 PM
dvp95's Avatar
I dont want to switch out my distributor. Im done with cars..haha I want to either keep the internal coil (not sure what model I would buy or if there are any that are interchangeable) or go to an external coil using the USDM prelude coil. Can I just buy the USDM coil and take the + and - wires from the internal coil and go to the external coil then use the USDM cap which is external?
Old Aug 12, 2008 | 05:05 AM
drbenne's Avatar
I used a coil from a 2000 civic si in my 94 jdm distributor, it might work for yours too. Just take out your old coil and compare it with a new one.
Old Aug 12, 2008 | 03:50 PM
kadidle's Avatar
Default Re: 97+ prelude internal coils? (drbenne)
or you could buy a used direct replacement type s distributor
http://cgi.ebay.com/ebaymotors...72960
Honda Type R
Apr 8, 2006 02:11 PM
b16hybridsol
Jun 20, 2005 02:50 PM
jdmcivicferio
Apr 28, 2005 10:30 PM
Prelude_1997
Oct 19, 2004 01:17 AM
