who runs ground control coilovers
Old Jul 22, 2002 | 08:30 PM
civbeater90's Avatar
Default who runs ground control coilovers
any suggestions on installing them?
[Modified by civbeater90, 5:32 AM 7/23/2002]
Old Jul 22, 2002 | 08:37 PM
andrew dc's Avatar
Default Re: who runs ground control coilovers (civbeater90)
just like springs.. you might not be able to use the stock dust covers over the shocks... they install just like springs if that is what you are asking
Old Jul 22, 2002 | 08:56 PM
Default Re: who runs ground control coilovers (CRX25)
did you cut your bumpstops?
Old Jul 22, 2002 | 08:59 PM
andrew dc's Avatar
cut them in half.. instrux tell you to cut them in half
Old Jul 22, 2002 | 09:30 PM
Art T. Fish L.'s Avatar
I didn't use the dust covers, but I probably should have used them and cut them, cause I think my shocks are bad already. I've had my ground controls and toikico blues since about april.
Old Jul 22, 2002 | 10:33 PM
CRXSleeper's Avatar
I run the GC on my 90 CRX Si. And i made the mistake of NOT using bumpstops on them simply from not knowing better. I learned the HARD way. My shocks gave in a few weeks. All you need to do is cut the stock bump stops in half or if you are getting aftermarket shocks, they all come with urethane bump stops. Either way, just make sure you install them. Installing GC's or any coilovers is basically the same as installing springs except you install a ring around them to adjust the height. Good luck. I know i spent a lot of hours experimenting and learning on experience on my own.
Old Jul 22, 2002 | 11:29 PM
silver89civic's Avatar
Default Re: who runs ground control coilovers (CRXSleeper)
what are the bump stops? can you show me a pic?
Old Jul 23, 2002 | 08:35 AM
Doodoo's Avatar
I got one for you. Use grease or WD-40 on the rubber sleeve that wraps around the strut body. Makes installation a snap.
Old Jul 23, 2002 | 08:48 AM
1.8Tities's Avatar
Default Re: who runs ground control coilovers (silver89civic)
Look at the upper right conrner... The yellow rubber thingy is the bump stop, they prevent the shock from bottoming out..
Old Jul 23, 2002 | 08:49 AM
Steve91's Avatar
I run them and cut the bumpstops in half. I also run the dust cover cut to GC's specs. GC's tell you to cut the cover down to 1" total length, which seems pointless to even keep it in there since its so small after cutting.
Old Jul 23, 2002 | 09:35 AM
Mr Furball's Avatar
Default Re: who runs ground control coilovers (Steve91)
I have alot of friends who run them and they all love them. they are just like stock ride but a little bumpy. I have taken rides in alot of cars with them and if I did not race my car then I would go with them.
Old Jul 23, 2002 | 10:51 AM
LD_EGSICK's Avatar
i don't under stand y u have to cut the bump stop in half for? can't u leave it how it is?.....do u do that also for springs?
Old Jul 23, 2002 | 01:17 PM
REDBARON's Avatar
Default Re: who runs ground control coilovers (CYBEREX)
Yes, you have to cut them when installing springs also. Like someone said, it gives you more shock travel.
Old Jul 23, 2002 | 06:55 PM
Default Re: who runs ground control coilovers (REDBARON)
did you guys put all the washers back?the gc instrux donesn't show any washers?also the instrux say to cut the top of the dust cover 1 1/2 inches?would it make a diference if i cut if from the bottm?i tried to call them today but i got there answering machine.
Old Jul 23, 2002 | 10:52 PM
Default Re: who runs ground control coilovers (4thGSi)
thanks!
Old Jul 24, 2002 | 08:43 AM
Doctor CorteZ's Avatar
Default Re: who runs ground control coilovers (FURBALL B-16)
I would like to know when EXACTLY you have ever RACED your car
macattack
Suspension & Brakes
Jan 21, 2005 11:36 PM
JMod
Sep 13, 2003 06:23 AM
integraautox
Dec 26, 2002 07:17 AM
Sohc-Vtec
12
Oct 4, 2002 05:22 PM
ruiner17
Feb 21, 2002 09:54 AM
