B18 Camshaft Lamp
Old Aug 11, 2008 | 02:54 PM
kp's Avatar
kp
Default B18 Camshaft Lamp
I thought this may fall under the fabrication section, so here it is. It's a B18 exhaust camshaft with the cam gear at the bottom. I used the crank pulley off of the same B18 but cut out the middle and bashed off the third belt section. The crank pulley is fixed to the cam gear with 4 bolts. The crank pulley wasn't quite as high as I liked so I cut out a circle of wood the same size and fixed it to the bottom to lift it up a bit. Pretty cool?
ps. the wall in some of the pictures is being renovated, so we've sort of drawn all over it.
*edit sorry some of them aren't rotated.
Old Aug 11, 2008 | 03:26 PM
Jasper_db1's Avatar
Default Re: B18 Camshaft Lamp (kp)
I like it except for the JB-Weld
Old Aug 12, 2008 | 07:47 AM
kp's Avatar
kp
Default Re: B18 Camshaft Lamp (Jasper_db1)
the jb weld was absolutely necessary. copper pipe doesn't thread well.
Old Aug 12, 2008 | 03:31 PM
i drive a honda's Avatar
nice, whats holding the copper to the cam?
are those rockers cut in half?
Old Aug 20, 2008 | 08:30 AM
kp's Avatar
kp
Default Re:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by i drive a honda &raquo;</TD></TR><TR><TD CLASS="quote">nice, whats holding the copper to the cam?
are those rockers cut in half? </TD></TR></TABLE>
there are two copper tubes holding them together as you can see in the last picture and those are rockers but they're not part of the structure, just for looks.
and they're not cut in half (b18 from a 96 integra)
Old Aug 20, 2008 | 01:25 PM
JDMs1eeper's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kp &raquo;</TD></TR><TR><TD CLASS="quote">the jb weld was absolutely necessary. copper pipe doesn't thread well. </TD></TR></TABLE>
you could maybe solder/braze them.
Old Aug 20, 2008 | 02:29 PM
PPLH8R's Avatar
Default Re: B18 Camshaft Lamp (JDMs1eeper)
You should have used a VTEC cam. Maybe the light would have been a little brighter.
Old Aug 20, 2008 | 03:09 PM
kp's Avatar
kp
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMs1eeper &raquo;</TD></TR><TR><TD CLASS="quote">
you could maybe solder/braze them. </TD></TR></TABLE>
The proplem there is that both of those methods need tremendous heat to work correctly. Unfortunately for my design, my wires run up the copper pipes, not up the cam. The heat would easily melt my wires and probably short out the whole lamp.
Old Aug 20, 2008 | 03:10 PM
kp's Avatar
kp
Default Re: B18 Camshaft Lamp (PPLH8R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PPLH8R &raquo;</TD></TR><TR><TD CLASS="quote">You should have used a VTEC cam. Maybe the light would have been a little brighter. </TD></TR></TABLE>
Haha, no I think it would make it want to race everyother piece of furniture in my house.
Old Aug 20, 2008 | 03:30 PM
Flip.'s Avatar
Haha, no I think it would make it want to race everyother piece of furniture in my house. </TD></TR></TABLE>
lol
Looks nice, man. something diffrent.
Old Aug 21, 2008 | 08:58 AM
Jasper_db1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kp &raquo;</TD></TR><TR><TD CLASS="quote">The proplem there is that both of those methods need tremendous heat to work correctly. Unfortunately for my design, my wires run up the copper pipes, not up the cam. The heat would easily melt my wires and probably short out the whole lamp.</TD></TR></TABLE>
I'm work in the custom lighting manufacturing and design industry. You could have inserted an uninsulated wire, brazed, and then pulled your insulated wire through with some lube. Just a thought for next time
Old Aug 30, 2008 | 02:59 PM
kp's Avatar
kp
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jasper_db1 &raquo;</TD></TR><TR><TD CLASS="quote">
I'm work in the custom lighting manufacturing and design industry. You could have inserted an uninsulated wire, brazed, and then pulled your insulated wire through with some lube. Just a thought for next time </TD></TR></TABLE>
Very very true. Cheers for the tip, i'll try something like that the next time i do tight wiring.
twistedbydezign
Sep 24, 2005 02:10 PM
RCautoworks
Mar 16, 2005 06:43 PM
spyderracing
14
Sep 26, 2004 09:10 AM
dpo95si
Aug 17, 2002 08:11 AM
Kevin
May 17, 2002 08:51 AM
