Help I have a very strange, but big problem.
Old Aug 11, 2008 | 02:52 PM
captaindammit's Avatar
Default Help I have a very strange, but big problem.
I have a 93 lude with a jdm h23A v-tec motor, apexi vafc, DC headers, and cold air intake. The car for a long time acted like it was getting any spark and wouldnt hardly run right. Since then, I've replaced the coil (which was bad), the plugs and plug wires (which were bad), and the distributor cap, which oddly enough wasnt bad lol. The car still will not start and I'm honestly at a loss here. Ive checked all the voltages throughout the ignition and electrical system and everything is working as it should. But, still no fire at all. It doesnt even attempt to start, just endlessly cranks. After a few cranks you begin to smell raw gas badly. Im honestly at a loss here, and am at the end of my rope. Suggestions? Ideas?
Old Aug 11, 2008 | 06:12 PM
mongtite's Avatar
Default Re: Help I have a very strange, but big problem. (captaindammit)
Did U by an chance use another Distributor????????
Old Aug 11, 2008 | 06:40 PM
Default Re: Help I have a very strange, but big problem. (mongtite)
no, i thought it might have been the dizzy, but after taking the plug wire off at the plug, i saw that it was getting good spark from the dizzy. so idk. i also checked all my relays and fuses, they all seem to be in good shape.
Old Aug 11, 2008 | 08:47 PM
Acidcrakker's Avatar
So your getting fuel and spark, but there is still no turing on?
The only thing left is comp
Old Aug 12, 2008 | 01:48 AM
218luder's Avatar
Default Re: Help I have a very strange, but big problem. (Acidcrakker)
you probably have a bad ignitor
Old Aug 12, 2008 | 10:17 AM
G2IntegraGS's Avatar
Yeah the spark might be weak. Im not sure how you check that tho. Has the motor ever run right?
Old Aug 12, 2008 | 10:28 AM
street_ride14's Avatar
Default Re: Help I have a very strange, but big problem. (G2IntegraGS)
Check your timing belt.
Old Aug 12, 2008 | 10:56 AM
218luder's Avatar
Default Re: Help I have a very strange, but big problem. (street_ride14)
heres some things you could try
1. try new distributor
2. main relay
3. 02 sensor(highly doubt it could be that)
Old Aug 12, 2008 | 11:26 AM
Rosko's Avatar
Default Re: Help I have a very strange, but big problem. (218luder)
swap a good dizzy in if you have one and try that.
1badcrx
May 1, 2009 08:39 AM
StreetRiot_DRE
25
Dec 10, 2007 07:19 PM
jdmstylez16
Oct 28, 2007 02:39 PM
intgraCA
Jul 27, 2006 09:12 AM
Ski11z
Apr 28, 2005 03:14 PM
