GSR Fuel Filter Leak (searched)
i did search for (fuel leak) but couldnt come up with anything related...
anyways 94 gsr i have a leak coming from one of the fuel line fittings onto the fuel filter. i dont have my car here at work but i think there are only two places that can be tightened/loosened on the fuel filter.
the line going from filter to rail is tight as can be, but the bigger fitting, directly on top of the filter, may be loose. i havent had time to check it yet but has anyone ever had problems with this before?
it has a Walbro fuel pump with AEM fuel rail running on a P05 ecu. ( i know its the wrong ecu, i have a p28 im swapping in today, will be chipped in a couple of weeks).
the guy who owned the car before me had a P06 ecu in it and when i test drove it, there wasnt any fuel leaks so im assuming its having to do with the fuel pressure ratio from the p05 and p06, maybe there is a differece? im hoping the p28 will solve that, IF that is the problem.
thanks
thanks
there is a "crush"washer on the top of the bolt and the bottom get a new fuel filter and new crush washers they usually come with the fuel filter.............
